Author Topic: What are the biggest tires you can fit under a '65 Galaxie?  (Read 10588 times)
Re: What are the biggest tires you can fit under a '65 Galaxie?
« Reply #15 on: June 15, 2018, 08:54:52 AM »
weld 12-6-3-9 o clock an inch at a time  you
can weld with the tire mounted if it is tubeless
    Here's something to consider about welding on wheels with tires:
    https://www.youtube.com/watch?v=jBUVzgCHHuA
Wow... :o guess i been lucky then. Welded at least hundred of them  not inflated but mounted
