Author Topic: Distributor Gear  (Read 14198 times)
hwoods
Distributor Gear
« on: April 25, 2018, 07:53:08 AM »
I will be running a roller cam I got from Barry R. Pertronix Distributor.  Most Bronze gears say not for extended street use.  I can't find where anyone makes a composite distributor gear for the FE Engine.  Anybody know someone that does make a composite gear?
Thanks
scott foxwell
Re: Distributor Gear
« Reply #1 on: April 25, 2018, 08:05:04 AM »
I'd stay away form Composite gears. If you get a good quality bronze gear it should last a LONG time. Or, depending on your cam core you might be able to go Melonite gear. You might call these guys: http://distributorgears.com/
« Reply #2 on: April 25, 2018, 08:17:38 AM »
Run a steel gear with that camshaft.   Crane or Mallory/MSD has plenty of gears to choose from depending on the shaft size.
scott foxwell
« Reply #3 on: April 25, 2018, 08:35:04 AM »
MSD gears are junk. Made in China. MANY problems with them.
« Reply #4 on: April 25, 2018, 08:43:11 AM »
I haven't had any problems at all with them, but I use more of the Crane stuff than the others.
TJ
« Reply #5 on: April 25, 2018, 08:51:31 AM »
I've got several thousand miles on a pertronix distributor and crane steel gear.  No complaints or issues.
hwoods
« Reply #6 on: April 25, 2018, 09:07:03 AM »
Thanks, ordering Crane Steel gear
« Reply #7 on: April 25, 2018, 11:41:29 AM »
FWIW - you'll recall I just lost a $400 solid roller cam to a Mallory steel gear.
« Reply #8 on: April 25, 2018, 12:17:27 PM »
Having blown through a bronze gear (my fault and street) I’m a little more than casually interested in this topic.
Didn’t know there were the other choices in gear suppliers, thanks.
BTW here is a melonite process link because I can’t be the only one that had no idea what it was. If I keep hangin’ around here there’s no tellin’ what I might learn. ;)
https://www.ibccoatings.com/melonite-qpq
« Reply #9 on: April 25, 2018, 12:26:03 PM »
There's really not that much to it.
A cast cam gets a cast gear.
A billet steel core cam gets a steel gear.
The others won't last well at all.
Most of the issues that guys have with gears that *should* work is that the gears are not positioned correctly on the shaft.  There is a spec for it and if it's not held, you will get gear wear.  You can't just pull a gear off, put a new gear on and line the holes back up.  It doesn't work like that.
« Reply #10 on: April 25, 2018, 12:26:56 PM »
Not sure what happened there with that one, but I have never lost a steel or cast iron distributor gear.  Ever.
scott foxwell
« Reply #11 on: April 25, 2018, 12:30:32 PM »
The largest engine re-manufacturer in North America (ATK) removes and replaces every MSD distributor gear they get. MSD used to use a US manufacturer for their gears @ ~24.00 ea. till they found out they can get them for ~2.00 ea. from China. The Crane (which is Comp) I'm sure, is also an offshore gear.
« Reply #12 on: April 25, 2018, 01:02:49 PM »
I didn't know it was used on cam gears, but seems like a good idea. Melonite is a very effective coating for gun mechanisms that are prone to areas of high wear and corrosion. My apologies if I've caused a red flag to the FBI, CIA or NSA for mentioning "gun" 8)
« Reply #13 on: April 25, 2018, 01:08:31 PM »
That's all fine and good, but still doesn't change my experiences.
scott foxwell
« Reply #14 on: April 25, 2018, 01:28:23 PM »
LOL...OK, whatever. I'm just trying to share useful information for others. Do with it as you please.
« Last Edit: April 25, 2018, 01:34:35 PM by scott foxwell »
