Author Topic: Some of what I do...  (Read 4830 times)
scott foxwell
« on: April 14, 2018, 07:51:53 AM »
Just thought I'd share some of what I do, mostly for entertainment sale. We all like cool pics of cool stuff, albeit mostly Chebby stuff.
This is a set of heads I just finished for a Drag Week customer.
This is a set of AFR 335's we're using as a foundation. Ultimately they will get alloy seats, oversize valves (2.375/1.85) and steel guides with liners on the exhaust. The engine they're going in will be 588 ci, 11:1 pump gas, single carb with a Steve Johnson single plate capable of over 800hp of N20.
Portng room R&D
Once I got the ports how I wanted them, we changed seat material on these. These will have CHE alloy seats and steel ex guides w/liners. The intake seats are .100" deeper and already to size...I had to deepen the hole, but not make it any larger in order to maintain the right amount of press. Normally, I would order slightly oversize seats (like I did on the exhaust) but that would have been a 6 week wait. These were in stock. Made my job a little tougher, but doable.
The head goes in the mill with the seat pockets squared to the head via the magic fixture from Pete Graves CPMotorworks Inc. Instead of moving the head of the mill, I just set the fixture by indicating the bottom of the pocket flat. Once set, they should all be the same...or will be when I'm done. Then I indicate the diameter of the pocket on each one and bore to size with the boring head. IN this case, I didn't want to take as much as a tenth out of the existing pocket if I could avoid it, I just wanted to make them about .09" deeper for the new seats.
Once the seat pockets were bored, the intake seats were installed. Next step is to bore the exhaust seat pockets. Because they overlap with the intake seats, these had to be done in order. Intake first, then exhaust. This is done in the seat and guide machine. Exhaust seats were .010" oversize but I cut them down to .005" oversize.
Cutting exhaust seats to size.
Adding a slight radius and polishing the edge for installation.
Once seat pockets are bored to size, exhaust seats are installed. Next step...surfacer.
With all the new seats installed, heads get a minimal surface before valve job just to make sure they're flat.
After surfacing, it's off to the seat and guide machine for valve job, then hand blending. I use a Sunnen VGS20. We have two in the shop.
https://scontent-atl3-1.xx.fbcdn.net/v/t1.0-9/30715531_1764112330319242_1235772574797922304_n.jpg?_nc_cat=0&oh=72e4fd39213c8bffed9a4f61ffcb1e7a&oe=5B2AE7CD
I also do a little mod to the area around the spark plug. This is before, as from AFR...
And after...
You can also see the finish blending on the valve job.
Finished ex port...
And of course, the results; These are final on the prototype ports, I will flow the CNC ports for comparison before all is said and done. I might work on the ex port a little more. 2.375/1.85 Ti valves, 50* valve job, 4.60 bore.
....Right / left / ex
.2 152 / 152 / 126
.3 230 / 236 / 200
.4 300 / 307 / 260
.5 354 / 350 / 294
.6 400 / 385 / 306
.7 431 / 413 / 316
.8 446 / 429 / 324
.9 450 / 441 / 334
1.0 454 / 449 / 341
« Last Edit: April 14, 2018, 07:53:28 AM by scott foxwell »
Re: Some of what I do...
« Reply #1 on: April 14, 2018, 11:18:26 AM »
Thank god for cameras.  It sucks to hide all the pretty stuff inside an engine :P
Looks great Scott.
wowens
« Reply #2 on: April 14, 2018, 03:22:05 PM »
That is purrty !
Woody
« Reply #3 on: April 14, 2018, 05:45:20 PM »
The valve seats are interesting.  The exhaust seats look like copper beryllium, is that what they are?  And I have no idea what the intake seat material is.  Are these heads getting titanium valves?
scott foxwell
« Reply #4 on: April 14, 2018, 07:59:17 PM »
Seats are pretty typical for this sort of build. Yes, Ti valves. Intakes are from CHE... B1 alloy intake and ex are BX...I believe the intakes are a brass alloy and the ex are copper but not beryllium. Something similar but I don't think anyone is using actual beryllium any more. That stuff will kill you.
« Reply #5 on: April 14, 2018, 08:45:35 PM »
I made some valveseats in my lathe for a rallycross engine
out of Extruded Aluminiumbronze
dont remember the mix but some nickel, iron, and manganeze
around 170-180 brinell hardnes
if i remember things right
Katz427
« Reply #6 on: April 14, 2018, 09:34:03 PM »
Very nice work. Appreciate the picture show.
« Reply #7 on: April 15, 2018, 07:22:42 AM »
Yes, thanks Scott for the nice detailed pictures.
Ghoughton
« Reply #8 on: April 15, 2018, 03:06:50 PM »
Very cool. I love looking at that kind of stuff regardless of brand. Flow numbers are
Nothing to sneeze at
