Author Topic: Adding power to a 390 help  (Read 9716 times)
NIsaacs
Re: Adding power to a 390 help
« Reply #15 on: February 07, 2018, 04:45:00 AM »
These guys will spend your money if you let them, Lol
I have been running FE's since the mid '60's and have never had a cam go flat. For your application, a roller cam is not necessary. They require a whole lot of expensive/complicated valve train support parts. I still say with your short block, the ED complete top end kit will work just fine, including the cam. If you are not careful this site will have you building a complete high performance engine. If you don't mind, then carry on, but that was not your original intent. A custom cam is fine, but I would still stay with a hydraulic flat tappet.
I am running this exact same kit on my 440, complete with an Edelbrock 800 carb, pertronics distributor and headman headers. It is simple, no special maintenance required and they work.  I like it....
Nick
Jim Comet
« Reply #16 on: February 07, 2018, 07:43:13 AM »
Why not try the new TFS heads as they have a 70cc chamber? Edelbrocks range from 72-76cc. Jim
fastback 427
« Reply #17 on: February 07, 2018, 07:53:18 AM »
speaking of blowing the budget and tfs heads, just wait until dueling 390's part 2 is done then.....
Jaime
top end toploader
67 mustang coupe project
74 f100 xlt 390 c6 factory ac
« Reply #18 on: February 07, 2018, 11:31:12 AM »
Do I remember reading that the TFS have a raised valvetrain base? Maybe added "cyphering" that's not necessary here?
Just asking as I'm also putting together a plan for a stock 390.
