Author Topic: my blown injected on alky flat bottom project  (Read 9167 times)
racer
« on: July 09, 2012, 04:52:44 PM »
below
« Last Edit: August 14, 2012, 09:28:04 AM by racer »
racer
Re: my blown injected on alky flat bottom project
« Reply #1 on: August 12, 2012, 08:46:37 PM »
figured out how to post a pic on here....my project. 431ci jeff
« Reply #2 on: August 14, 2012, 08:37:15 AM »
Great looking motor.  Can you post some of the details here?  I don't do facebook  :P
racer
« Reply #3 on: August 14, 2012, 09:27:24 AM »
431ci
d3te block filled to almost the deck and girdle installed
rpm crank
je 12-1 pistons
crower pro billit 6.7 rods chev  big end
comp roller and enduro lifters
melling hv pump blue printed
14qt dooley pan and pickup
rcd blower hub and nicoson front cover with stack enderle/river rat pumps
edel heads with triple springs and light port match work only milled .060
smith bros push rods
hd dove rockers with end stands
dove intake
mooneyham 6-71 stripped and anodized for alky
3300cfm bird enderle with square valve and high speed bypass setup
msd with 7 box and 2amp coil
rearward zoomies
thats the basics..
 jeff
drdano
« Reply #4 on: August 14, 2012, 11:27:17 AM »
Have you dyno'd it?  Glad to see an FE on the float.  My first V-drive was FE powered and someday I'd like another.  Wicked fun.  I assume this is a dedicated race-only boat?
racer
« Reply #5 on: August 15, 2012, 06:53:30 AM »
hope to pull it at barrys place soon,and no this will also have some lake fun but with the block full and the fact my bullet tank only holds a small amount of alky with to side saddle tanks and an electric pump to feel the buttet we can lake play some but limited.. jeff
