Author Topic: FE Power at the PRI Show  (Read 27923 times)
« on: December 06, 2017, 08:46:01 PM »
This year I'm displaying my products at the PRI show in Indianapolis.  Drove all day to the show yesterday and spent most of the day today setting up the booth.  I have a few new products to display at the show, plus the normal parts.  This post is a quick overview of the display and products.
Here's the booth after it has all been set up.  The booth number is 7137:
The photo below shows some of the valve cover prototypes that I have machined recently.  The day before Thanksgiving I finally got some prototype valve cover castings with the surface finish quality that I require.  Its been exasperating that it has taken this long, but I think the foundry has it right now and can deliver good quality castings.  I expect to get the first production order of castings in January.  A couple of the castings have been powder coated, and some have been engraved; I will be offering these options to the folks on my valve cover list when I get the production batch.
Also of note in this photo is a 351C Hilborn EFI setup, which of course bolts onto my intake adapter.  It can be fitted with butterflies up to 2-5/8" diameter.  Since I made over 900 HP with the 2-7/16" butterflies on the Hilborn setup on the SOHC, I'm sure this induction system is capable of those kinds of numbers:
I'm also introducing some new products at the show.  First is the billet intake shown in the two photos below.  Some of you may have seen the red 3D printed version of this intake at the FE Reunion last April.  I now have the machining programs written for this intake and have made my first prototype.  There are a few minor machining errors but overall it looks pretty good I think.  This manifold will bolt onto my standard 13001 intake adapter, or any 351C with stock type heads for that matter.  It uses a Holley LSX top, but I am also considering machining a billet top for this intake.  That would be more expensive, though.  I am currently working on a similar intake to bolt onto my high riser intake adapter.  Once that is finished, probably mid-January, I will be making both these billet intakes, plus my tunnel port billet intake (already shown in the Member Projects thread) available for general sale.  Price on the billet intake for the #13001 will be $1500:
Next on the new product list is a set of SOHC rocker arms.  These are unique in that they replace the needle bearings in the roller wheel with bronze bushings, like the more modern roller lifters.  The rockers are drilled with oil holes so that the bushing is provided with full time pressure oiling.  I have burned up way too many needle bearings in my SOHCs, with the resultant engine damage, and am looking forward to testing these rockers out on my engines.  Assuming they pass muster after a summer of running and next year's Drag Week, I will make them available for sale.  Photos of the rockers are below.  Note that they have a roller tip, so they will require lash caps of varying thicknesses in order to set the lash:
Last, but not least, is the FE Power cylinder head I've been talking about for some time.  The head design is not yet complete; it still needs the water jacket design, and a tweak or two to the intake port.  But, for the most part the basic concept is done.  Below is a picture of the intake port side of the head.  The intake port is nearly the exact same size as a standard FE medium riser port.  However, the port is raised substantially; the floor of the port is about 2" above the deck surface:
With an intake port this high, of course the valve cover rail has to be raised as well.  Way back when I was doing my intake adapter design for the high riser, I was thinking about doing my own cylinder head, so I had the HR intake adapter cast with the valve cover rail over an inch higher than a standard high riser valve cover rail.  Basically, this means I can machine the high riser intake adapter casting to fit these ports, and maintain the standard FE valve cover rail shape, despite the radically raised ports in the heads.  Basically, the valve cover rail is just raised up high enough on the heads and intake to clear the revised intake port.
I plan to make three different intake setups available that will fit this intake adapter.  One will be a billet intake like the one shown previously, another will be a single four spider style intake, and the last will be a crossram style individual runner intake, which I hope to be able to design so that it will fit under the hood of a Mustang, Fairlane, or Torino.  The billet intake and spider intake could be either carbed or EFI, but the crossram IR intake will be EFI only.
Along with the raised ports, they are also straightened, to take the hook out of the normal FE port.  This requires radically offset rocker arms, a 1.4" offset on the intake rockers and a slight 0.1" offset on the exhausts, to clear the intake ports.  The picture below shows the 3D printed rocker assembly.  There are 8 3/8" bolts holding the stands in place to allow for big valve spring pressures, and end stand supports for the shafts of course.  The shafts are normal FE size, but there are no through bolts to weaken the shafts and the oiling holes are positioned differently than stock.   This valvetrain will still oil through the rocker shafts, like the stock oiling system.
On the exhaust side, the ports are radically redone.  They exit the heads at a 45 degree angle, or straight out  horizontally with the engine in the car.  Obviously, custom headers will be required, and the exhaust will not fit in a shock tower car without some shock tower surgery.  A picture of the exhaust side of the head is shown below:
The chambers, shown in the photos below, are similar to other modern, heart shaped chambers with a centrally located spark plug and plenty of quench area.  Valve spacing is 2.025", and valve sizes are 2.25" on the intake and 1.65" on the exhaust, and valve stems are 5/16".  The valve angle is also decreased to 11 degrees, from the standard FE angle of 13 degrees, and the valves have been moved in the chamber to provide better flow into the cylinder than the stock FE valve position.
Obviously, with such a radical revamp of the basic FE cylinder head, a lot of things on the engine have to change.  If you want to run these heads, you will have to get the heads, the rockers and shafts, the intake adapter, the intake, and new pistons to match the revised valve location.  Plus, you would have to build your own headers, and cut the shock towers if you have a shock tower car.
What's the payoff?  Preliminary flow tests show that with the stock FE port size, the intake port flows 405 cfm at .700" lift, using a 4.25" bore for the cylinder.  The exhaust flows 270 cfm at .700", into a 2" OD header pipe.  The water jackets will be designed so that extensive porting will be possible.  A 500 cfm FE intake port may be possible with this design, after porting.  The photo below shows a 3D print of the ports:
Obviously, I'm a long way from having these available.   But personally, I really want a set  ;D  I plan to finish the design of the water jackets and intake port soon, and then get the intake options designed and 3D printed.  Next step would be to build a billet set of these heads for testing purposes on my 725 HP dyno mule.  I would expect the heads to add 100+ HP over the ported Edelbrocks that are on that engine now.  Assuming that testing all goes well, I will start looking into getting the heads and intakes cast and making a limited quantity available for sale.
I hope I get to see some forum members at the PRI show.  Please stop by and introduce yourselves if you make it to Indy - Jay
« Last Edit: November 21, 2018, 10:56:22 PM by jayb »
Re: FE Power at the PRI Show
« Reply #1 on: December 06, 2017, 09:45:46 PM »
All the products look good but those heads are freaking awesome ! Great job Jay
cwhitney
« Reply #2 on: December 06, 2017, 09:54:11 PM »
Very impressive Jay.
« Reply #3 on: December 06, 2017, 10:20:25 PM »
Is it just me Im not getting any pictures
« Reply #4 on: December 06, 2017, 11:42:48 PM »
Looks awesome, Jay! Sure would love to see a 400+ FE intake port.  Flowed a D3 SBF head with 2.135" valve recently that went 410 cfm @ .750"  The port volume was impressive.  Would love to see a FE with similar flow capability.  Hope yours can make it happen.  Joe-JDC
« Reply #5 on: December 07, 2017, 12:38:50 AM »
Very impressive stuff Jay. The heads are quite cool, I think i'd prefer the exhaust ports to look a little more normal than that and it could probably be done without harming those flow numbers... like the various "Cleveland" type heads, SC1's, etc.
Are the rocker shaft bolts angled inward as it appears? It looks like the intake side one must or they'd run off the head.
Cyclone Joe
  • Joe
« Reply #6 on: December 07, 2017, 12:46:18 AM »
Allllllllriiight!  Those rockers sure look good!  I meant to ask if the oiling passageways that you drilled gave you much trouble given the L/D?
Joe
427Fastback
« Reply #7 on: December 07, 2017, 12:57:08 AM »
Very cool Jay.....As a machine fitter by trade and know the carnage of needle bearings all to well I am glad to see the switch to bushings...I really like the look of the billet intake....Well done
1936 Diamond T 212BD
1990 Grizzly pick-up
« Reply #8 on: December 07, 2017, 06:24:39 AM »
Don't believe the OEM dog-legged ports could flow well enough, even with the raised and re-contoured design, to achieve anywhere near the flow Jay expects. I applaud the new design even though customs would be needed. Besides, it seems that merely due to the raised port, even with OEM dog-legs, a custom set of pipes would be required in any shock towered Ford.
« Reply #9 on: December 07, 2017, 06:31:13 AM »
The booth looks great Jay! Talk about an impressive group of hard parts. The head is the real star! Love the entire design concept but especially the straight exhaust port design! Could you, when time permits, give us a run-through on how you essentially transferred (I guess) a CAD design to the actual head that we see? Was the head produced on the rapid prototyping 3D machine?
« Last Edit: December 07, 2017, 06:32:54 AM by machoneman »
Ghoughton
« Reply #10 on: December 07, 2017, 07:00:35 AM »
Those heads are outstanding! I’ll be buying at least one set as soon as they’re available.
I love that you could make such radical changes and retain the stock valve cover. To me that’s
About the only part of the “fe” look that’s important. And the intake port spacing resembles a
tunnel port lol.
« Reply #11 on: December 07, 2017, 08:57:15 AM »
Stating the obvious here, but that's some pretty neat stuff.
What are the SOHC rockers made of? I can't tell if they're aluminum or some sort of steel.
Just looking at the pictures, the chamber design of those heads look like they have a nice shape, but the contour around the intake valve looks like it could use some work. It probably always seems like I am picking out flaws on your new desgins, but I'm just trying to help point out some areas of importance. Manufacturers have come a long way in recognizing the importance of the chamber contour around the intake valve/valves in directing flow patterns into the cylinder, not only for flow, but most importantly for swirl patterns in aiding fuel mixture and flame control. I think the BBM heads were the first FE head to start to take advantage of this modern thinking. I'd spend some time researching what some of the newest engine designs are using to improve that area. There are lots of advantages to this area that they are just beginning to understand and incorporate into the latest designs. Just an opinion from somebody who has no real experience in design, so take it for what it's worth.
That billet intake just looks badass!!
« Last Edit: December 07, 2017, 09:02:56 AM by cjshaker »
« Reply #12 on: December 07, 2017, 09:07:18 AM »
The SOHC rockers are 4130 steel, much like T&D use for their good stuff.  They should be bulletproof.  I can't wait to set eyes on this stuff when I'm there Saturday!
babybolt
« Reply #13 on: December 07, 2017, 09:20:11 AM »
Any change in ratio on the new rockers?
Royce
« Reply #14 on: December 07, 2017, 09:32:40 AM »
Awesome parts Jay!!  Now i know what you have been up to the last 3 mo... I am studying the parts to see what i can adapt to a MEL or Y block!
1961 Starliner 390/375 clone
1965 GT40 tribute w/FE
1992 BMW V-12 5.0
2001 Lincoln 5.4 4 cam
2000 Jaguar XK8 (Ford V8)
