Author Topic: Question - Eagle or Scat 3.98 crank, either easier to internally balance?  (Read 19196 times)
Just getting back from a family vacation...
No info on the Eagle.  But we've done a few of the Scat ones.  They usually balance internal pretty easy - but often still need weight in the rear.  Less than when using a factory crank.  Very much determined by the piston & rod selection.  The lighter you go the less metal we're adding & we can just drill/grind.  With tungsten costing around $60-75 per slug installed this sometimes pays for a piston upgrade...
Barry, looks like a max bobweight of 2100 grams, but I could pull more out of them if I wanted, all the parts have plenty of pad left.
That's lighter than my 489, but do you consider it light or heavy for an internally balanced 3.98?
