Author Topic: Photobucket  (Read 11563 times)
TimeWarpF100
Re: Photobucket
« Reply #15 on: September 05, 2017, 10:30:21 AM »
Testing: I did not pay the 399.00 Ransom.
Like barry I have 1000's of photo bucket pics on the web.
Seems to be working but i did get a message that late in 2018 I will have to pay the 399.00 or lose the photo's.
To work here it takes a different link than other forums. but works!
« Last Edit: September 05, 2017, 10:33:18 AM by TimeWarpF100 »
Lenz
Re: Photobucket
« Reply #16 on: September 05, 2017, 01:37:39 PM »
Great pics those.  I went very deep into photobucket, considered it more of a hassle.  Of course, I still use a flip phone so my technology level is waaaaayyyyy behind the times.  The resize down in paint is more my speed
Len Zielinski
'64 Galaxie 500 445 Toploader
'69 F100 300 stick
GJCAT427
Re: Photobucket
« Reply #17 on: September 06, 2017, 05:06:38 AM »
Lenz, is that the pickup you bought? You been holding out on me! Statics Please! You should have brought it to Midway Pak Monday over 375 cars showed.
Lenz
Re: Photobucket
« Reply #18 on: September 06, 2017, 11:49:58 AM »
No stats to mention Garry, bone stock manual everything '69 with a fresh later model 300 in place of the 240.  Painted this way in early 80's with a fresh interior and sat for 30+ years.  Solid truck with a little rust in the usual spots.  Only rot was localized in the left front cab mount bottom which took out the column and wiring like they always do.  Replaced the mount, went over the column, rewired with an NOS turn signal switch, modernized the ignition a touch, threw some tires on and sorted the rest out.  Runs and drives straight.  Thought about making it out your way for a first Monday, couldn't seem to get clear.
Len Zielinski
'69 F100 300 stick
GJCAT427
Re: Photobucket
« Reply #19 on: September 06, 2017, 03:38:55 PM »
Lenz, it was a first Friday and we had the last one last weekend. There is a cruze at the Cassadaga legion the 20th of this month. I just realized it may be a conflict for me, we`re supposed to go to Hannibal NY for the True North Coleman get together, I think its that weekend.
Lenz
Re: Photobucket
« Reply #20 on: September 06, 2017, 06:16:10 PM »
This year is getting a bit long in the tooth, I'm figuring on pulling the 3 speed out of the truck this winter and installing the overdrive that was in the Galaxie when I bought it.  Everything's a dead on match, just need to shorten the driveshaft a bit and I've got a spare propped up in the corner just waiting for a job.
Len Zielinski
'69 F100 300 stick
Bolted to Floor
Re: Photobucket
« Reply #21 on: September 07, 2017, 10:19:29 PM »
I opened a Postimage account and its easy to use. But I haven't found a way to edit photos, mainly rotate them. They were right on my PC, but rotated when uploaded.  >:(
How is Flickr??
Re: Photobucket
« Reply #22 on: September 08, 2017, 08:47:08 AM »
John, Flickr seems to work fine.  I used on my Latest FE post.
