Billet aluminum caps, the way it is supposed to be. If Ford had billet aluminum back in the day before CNC, they would have used it instead of cast iron or ductile caps. The "easy" way to change the rocker ratio in a SOHC would be to use a smaller diameter rocker shaft, possible on stock head with offset bushings.Just wondering if anyone has gone to the Flathead/351W firing order yet on the SOHC camshafts?
