Author Topic: Gene Berg , (Weber Style) Carburetors  (Read 12361 times)
Wortttie
Re: Gene Berg , (Weber Style) Carburetors
« Reply #15 on: August 08, 2023, 03:33:46 PM »
Hello Again.
I forgot to ask one more question to Jay or anyone that wants to respond.  I am currently running some Blue thunder medium riser heads.  But I have a virgin set of Blue Thunder High riser heads.  I will be getting these ported to put on my engine so my question to Jay is do you have an adaptor that can be used with the high riser heads?
Thank you
Phil
« Reply #16 on: August 08, 2023, 03:40:34 PM »
Phil, I do make an adapter for high riser heads, link below:
https://www.fepower.net/Products/feiahr.html
Also, when testing the Webers I did not have any issues with idle, in fact they really seemed to idle well.  The Webers require much lower fuel pressure than normal though, so I set my fuel pressure at 3.5 psi.  Too much pressure will overcome the floats in those carbs and cause lots of problems.  Hope that helps - Jay
Wortttie
« Reply #17 on: August 09, 2023, 04:37:35 AM »
Thank you Jay.  That is a help
kcoffield
    • inlinecarb.com
« Reply #18 on: August 09, 2023, 11:41:42 AM »
If anyone has anymore information relative to anything regarding the use of weber style carbs I am most interested.
PM Sent
Best,
Kelly
