Author Topic: MSD pickup coil Bad?  (Read 4633 times)
ymountainman
« on: June 10, 2012, 10:03:06 AM »
Well i got my fuel problems fixed and went out to start the truck sat morn and no spark. I had trouble last weekend too. I thought it was the 2pin connectors on the pick up. I cut them and used some crimp on connectors to replace them. This is a new pro billet 8594. Any way i pull the coil wire and ground it and crank the motor and no spark. I then jump the 2 wires going out to the box and it sparks fine. Got to be the pickup? Right? I also ohmed it with my fluke and im getting 250ohms. Im pretty sure its the pickup do yall have any suggestions. Im gonna call msd tommorrow. Thanks!
rcodecj
Re: MSD pickup coil Bad?
« Reply #1 on: June 10, 2012, 10:56:13 AM »
You should get 500 to 700 ohms measuring the pickup. Odd that you get 250 ohms, the ones I've seen fail usually measure open.
http://www.msdignition.com/page.aspx?id=3304
