Author Topic: CVR Pump Lesson Learned  (Read 15947 times)
« on: July 16, 2017, 07:43:53 PM »
I installed a CVR pump last week, with Jays adapters. I also installed an "old Air" electric fan setup and a larger capacity alternator. Yesterday I filled water and backed the car out to try it. No leaks, everything was fine so I took it around the block and got it warm. When I got back to the house I parked it in the driveway to idle for a bit to make sure it could handle itself. It cooled perfectly and I was real happy.
Just after I shut the car off, we were standing around BS-ing about how great it worked etc etc....it started leaking. Took a while to figure out where from, but it was coming from the seal between the motor and the housing on the water pump (CVR's problem). I did a google search to figure out if it's a common problem and the first search result I found was from FEPower.net! Turns out someone on here has had the same problem in the past.
I'm going to call CVR in the morning and try to get them to warranty me a motor gasket. Save yourself some headache and pull the pump apart and seal it prior to using one.
Re: CVR Pump Lesson Learned
« Reply #1 on: July 17, 2017, 07:01:01 AM »
Thanks for the heads-up on this issue.  Just for your information, though, you can't just take those four screws out of the front side of the pump and take it apart.  I've tried that, but it won't come apart that way.  Back during Drag Week in 2015 I tried to take mine apart (thought the pump had stopped working, but it turned out to be an electrical issue).  Removed those four screws and the pump still wouldn't come apart.  I'm not sure what else has to be done to get it apart; maybe CVR will be able to tell you...
« Reply #2 on: July 17, 2017, 10:17:46 AM »
I emailed them this morning. I asked them to send me detailed instructions on how to fix it and to send me any materials necessary. I'll post up their reply.
Has me wondering if you take off the front plate and then get at the motor screws from the back side.
It's leaking from between the black motor and the aluminum.
« Reply #3 on: July 17, 2017, 10:36:35 AM »
Again, why I CRINGE every time I see an electric water pump like those.
I hope they take care of you.
« Reply #4 on: July 18, 2017, 01:24:35 PM »
How long ago did you buy the pump? Just curious because I JUST bought one, but it probably won't be used for about a year. I'll be interested to see if CVR takes care of the issue, without a hassle. Guess maybe I need to try mine and make sure it'll work when the time comes. I ass-u-me(d) the pump came apart easily and that there was a simple replaceable seal behind there. How stupid of me ::)
« Reply #5 on: July 18, 2017, 05:13:15 PM »
Update: I've called and talked to the secretary lady twice today, trying to get to some sort of deeper technical assistance or manager but haven't been able to connect with anyone, I've only been able to sit on hold with her while she talks to the people and relays the message. Currently they want me to take the whole unit back off and ship it to them so they can inspect it and make sure I haven't caused damage to the pump, and then they'll decide what they can do to take care of me.  Or, if I really need to use the car, they see no problem in having a slight leak to get me through the summer, or until the pump completely fails (their words not mine). They are based out of Canada so the secretary wanted my social security number so she could set up return shipping. No.
My first call in I was only simply asking for a new gasket and instructions on how to replace the gasket. From how she responded, it got me worried that the water that is leaking is actually infiltrating the motor case.
I shut it down for the day because every transfer phone call she tried didn't go through, I'm going to call back in tomorrow. See if I can't talk to someone who can do something about it.
Nothing too frustrating yet. The solution I'd like to arrive at is them sending me a new motor and front plate assembly.
« Reply #6 on: July 18, 2017, 05:15:50 PM »
Bought this in the middle of last month. I also assume its a seal behind there. I'd typically just take it apart and look at it, but I want to leave it alone for now so I don't mess up some sort of warranty claim.
« Reply #7 on: July 18, 2017, 05:38:11 PM »
By the way, here's some install pictures......rather than just the bad news!
Jays adapters worked out great!
I had help:
« Reply #8 on: July 18, 2017, 05:42:21 PM »
Sorry to see you are not getting great response from CVR.  This afternoon I decided to do a little more investigating on this, since the only time I'd ever tried to take the pump apart was on the side of the road during Drag Week in 2015.  I have a new pump here on the shelf so I took a look this afternoon.  First, there are four screws holding the electric motor in place.  I took those out and started pulling the case off the motor, but I only had to pull it apart 1/8" or so to see that I was into disassembly of the motor windings and brushes and so forth with this approach, so I just put it back together.  Then there are four screws that look like they would crack the case in half and expose the gasket.  These are the four screws I was talking about in my earlier post.  Just on the off chance that the pump I already tried this on was stuck or something, I took those four screws out, but nothing came apart.
I thought that maybe it wouldn't come apart because the case halves were pressed together, or else that the impeller was on the other side of the case, and keeping it from being pulled apart.  I looked through the inlet fitting opening and after rotating the impeller a couple times I saw a set screw in there.  It would have been really difficult to get at, though, and it appeared that it was held in place by Loctite, so I didn't even try to unscrew it.
While I was mulling this over, it finally dawned on me that maybe the screws that held the motor together also went into the other side of the aluminum case (Duh - slaps forehead...).  Sure enough, two of the four motor screws were longer, and hold the motor to both sides of the aluminum case.  Here's a couple of pictures of the case, which came right apart when I pulled those two motor screws.  Also a picture of the impeller side, showing the set screw, which would now be easily accessible:
My guess is that there is a shaft seal behind that impeller, and that is what is leaking on Mike's pump.
« Reply #9 on: July 18, 2017, 08:24:22 PM »
Or a simple sealed bearing since that acts as the front of the motor case.
Now we know the meaning of "No User Serviceable Parts Inside" ::)
« Reply #10 on: July 18, 2017, 08:39:39 PM »
I'm liking the shop Dog Brunson. I have a couple shop cats, most of the time there as dirty as i am and into everything. Grinder's, welding, open headers, hardly anything fazes them. Strange though, the shop vac gets um every time. LoL. Of course they come right back soon as i shut it off.
I love cats and dogs, all animals really. Nothing better than patting a dog or rubbing its belly or have a loyal cat jump in your lap after a hard day. At least for a moment it makes things seem better. Least for me..
« Reply #11 on: July 19, 2017, 02:36:23 AM »
Oh my thats a beautyful Cougar you got there like it a lot
« Reply #12 on: July 19, 2017, 08:46:32 AM »
FWIW - I have a ProForm pump on the 302, been great for the last 3 years.  No issues at all.  I had one on the shelf as a backup and I sued it on the dragster 351C build.  It leaked from the get-go.  Same place, looked like out of the motor.  Bummer.  I did learn on the other pump that it's a good idea to separate the casting from the motor on a new ProForm and spray the gasket with High Tack, or other sealer.  But that didn't help the backup unit.  Not a lot of love in some places for CVR so I went with Meziere.  Expensive but hasn't missed a lick.  Bolt on and go.
« Reply #13 on: July 19, 2017, 09:28:48 AM »
Thanks for looking into that Jay! I appreciate it.
« Reply #14 on: July 19, 2017, 09:29:25 AM »
Thank you!
