Author Topic: Largest Bore and CID Of FE ?  (Read 17572 times)
TJ
Re: Largest Bore and CID Of FE ?
« Reply #15 on: July 12, 2017, 05:17:22 PM »
With budget in mind, a standard bore 352 stroked to 4.25 will make a "427" and a relatively easy 450 or more hp.  While it's not the magic 600hp, it will still make a Cobra "clean the ditches" as they say... just something to think about.
« Reply #16 on: July 12, 2017, 08:19:04 PM »
Maybe a better question is "how many cubes" can we adequately feed with current FE head capabilities?  The best wedge heads I have seen are right around the 400cfm range, while the best SOHC heads are in the 450-460 ranges.
scott foxwell
« Reply #17 on: July 12, 2017, 09:16:04 PM »
Valve size is something to consider as well...
wcbrowning
« Reply #18 on: July 12, 2017, 09:43:12 PM »
So what displacements are those respective flow ranges adequate for?
chris401
« Reply #19 on: July 12, 2017, 10:31:21 PM »
Regular FE, not SOHC:  4.440 bore x 4.400 stroke = 545.004 cubic inches.  Shelby big bore option, or BBM taken out to 4.440 will supposedly still have enough thrust wall to be safe.  It has been done.  Joe-JDC
That's a big FE. Is it around here?
« Reply #20 on: July 14, 2017, 09:34:30 AM »
"I know nuthin'".  The billet Moldex 4.400" stroke was accepted as the longest stroke feasible, and Shelby offered special liners called the "Big bore" option for years.  My personal BBM is 4.390" x 4.375" for 530 cubic inches.  My Shelby is 4.250" x 4.125 all aluminum.    Joe-JDC
67gt350
« Reply #21 on: July 20, 2017, 01:01:15 PM »
I like the point Barry brought up. If you could get to 600 plus cubic inches where/who is going to have a cylinder head/intake combination to feed it. Certainly nothing that isn't custom all the way.
TJ
« Reply #22 on: July 20, 2017, 02:29:29 PM »
Considering all the aftermarket parts out there, the FE can be built well beyond its original design in terms of displacement and performance.
« Last Edit: July 21, 2017, 04:47:14 AM by TJ »
427HISS
« Reply #23 on: July 24, 2017, 09:33:32 PM »
Joe,  the BBM's 4.390" x 4.375" for 530 cubic inches is great. Just wish I could afford one.  ;)
« Last Edit: July 24, 2017, 09:35:23 PM by 427HISS »
