Author Topic: FS/FT All Ford original Tri Power set up, very clean, complete with air cleaner  (Read 3296 times)
scott foxwell
Selling a complete, all factory tri power intake, carbs and air cleaner. All factory carbs, linkage, fuel log and air filter. Just went through the carbs and cleaned, installed new bowl and metering block gaskets and bowl screw gaskets. Carbs are in excellent condition. No corrosion, no damage of any kind. Carbs have not been re-colored, they are original.
Intake was thoroughly cleaned and two holes repaired with helicoils. One valve cover rail hole and one thermostat housing hole. Otherwise intake is in perfect condition with no coolant corrosion or damage of any kind. All flat surfaces were sanded, intake was glass beaded and thoroughly cleaned in both a spray wash cabinet and by hand. Only thing not original is the phenolic spacers between carbs and intake. Intake does not have the heat shield underneath. This came off my running 390 GTA. See pics for details. Asking $1850 plus shipping.
Also looking for FE blower intake. FPP, Blue Thunder, etc...nothing welded, want the real thing.
Scott
805 350 1159 cell
423 391 7774 wk
sfoxwell@straubtechnologies.com
« Last Edit: June 18, 2017, 02:36:51 PM by scott foxwell »
scott foxwell
