Author Topic: Ebay Item  (Read 13778 times)
Re: Ebay Item
« Reply #15 on: June 10, 2017, 06:55:52 AM »
I'm actually thinking of buying the cross-bolt mains as well and have them machined at the same time.. if that's even possible??
Yes.  It's possible to use both cross bolt caps and a girdle.  I talked with a machinist about that at one time.  I don't know how much benefit it is or if it's worth it vs. going to an aftermarket block.  I decided to just get some Pro Gramm cross bolt caps.
I'm not negative about the FE girdle, though.  I wouldn't mind trying one.  I am negative on main cap girdles on other engines, where just the tops of all the caps are connected.  That seems like a waste.  The "Y-block" design of the FE makes it, make sense, to me.   A big block Mopar would be the same way, where you can tie the caps to the block, instead of just to each other.
JMO,
paulie
FElony
Re: Ebay Item
« Reply #16 on: June 10, 2017, 05:57:31 PM »
pssssst paulie...huffed kitty at 3:12...  https://www.youtube.com/watch?v=sx9P4OYibwI
Riskit1234
Re: Ebay Item
« Reply #17 on: June 10, 2017, 08:42:17 PM »
now we're talking...
Re: Ebay Item
« Reply #18 on: June 11, 2017, 09:10:37 AM »
Neato!   Any idea what mill is in that '69?
I assume the Beater Bomb is an LS since he won't open the hood?
FElony
Re: Ebay Item
« Reply #19 on: June 11, 2017, 12:02:18 PM »
Now I do: https://www.facebook.com/ProCharger/photos/a.386278516781.171553.8741616781/10152271419501782/
Also, same meet from Cougar's angle. All Ford:  https://www.youtube.com/watch?v=Xrh1ROuFqn0
Quote
I'm thinkin' same. Anything with "bomb" in the name has to be Chevy powered.
Re: Ebay Item
« Reply #20 on: June 11, 2017, 02:43:40 PM »
Quote
Cool car!  Maybe the Drag Week guys, Jay or Doug or someone else?, have met Gavin and seen the Frenetic Feline?
« Last Edit: June 11, 2017, 02:45:40 PM by plovett »
Riskit1234
Re: Ebay Item
« Reply #21 on: June 11, 2017, 05:41:12 PM »
FElony
Re: Ebay Item
« Reply #22 on: June 11, 2017, 07:44:18 PM »
Do you know anything about little kitty?
Not sure what you mean. Did you see my links a couple posts up?
Riskit1234
Re: Ebay Item
« Reply #23 on: June 11, 2017, 09:37:29 PM »
Sorry...
I was just asking if you know anything about the cougar?  I actually watched that 1320 but missed the cougar when I saw it.. you pointing it out made me pay attention.   If you read the comments someone wrote it was ugly... it was so clean!  Cougar was hanging down low against a car that trees everybody.
Riskit1234
Re: Ebay Item
« Reply #24 on: June 12, 2017, 12:18:24 PM »
My bad I didn't see the last 3 posts... thanks for posting.
