Author Topic: Cross-ram intake  (Read 10978 times)
Riskit1234
Re: Cross-ram intake
« Reply #15 on: June 04, 2017, 06:20:49 PM »
It would go in a 73 F250.  I figured it was tall and thought if I added spacers it be even taller but I do have some room under the hood.  Do you know how tall it is?  Or maybe an idea on how much taller it be then a performer rpm (have now).
Thanks
« Reply #16 on: June 04, 2017, 06:46:37 PM »
Way freaking taller LOL but, I bet it has a good chance to fit under a truck hood.  We needed a Boss 9 scoop on a 67 Mustang, but that's a whole different animal
As far as low end, we didn't see a low end power issue, they are long runners which help torque, but as Jay said, you need a good pump shot if you foot tries to go deep into it in a hurry.  A pair of blue pump cams would likely do it on a pair of 600s, worst case, go up a size on the shooter to get it there quicker. If you have a good timing curve and not overcammed, I doubt it would be that much trouble.
FERoadster
« Reply #17 on: June 04, 2017, 11:09:02 PM »
Measured my F-66 and M/T compared to my RPM both are about 2.5 inches taller.
But for the M/T you need the special Distributor adapter and modified Distributor.
Ford 3X2 Look great and are affordable as well
If you want a really unique intake look at a Weber setup or the one I have for my Low Hood car a F-68
I'm patient and haven't paid more than $400 for any of my Intakes. I just put a sign at Swap meets "Ford FE HiPo parts wanted" and they come to you.
Of course this is SW Oregon and no one knows what a FE is.
Richard >>> FERoadster
« Last Edit: June 04, 2017, 11:15:40 PM by FERoadster »
« Reply #18 on: June 05, 2017, 09:03:14 AM »
 TommyT made one into a 4- 2 barrel holley's with two barrels right above each port if I remember correctly
Tommy-T
« Reply #19 on: June 05, 2017, 03:05:59 PM »
Well...
All of my experience is with the M/T Power Ram. In Jay's testing it was well down on power from the Edelbrock ram.
Took some fiddle'n 'round with but basically you need a lot of initial timing and pump shot. The linkage is as simple as a door hinge and two rods going out to the carbs.
I drove my '56 T-Bird with a mild 428 and the Power Ram for several years, even in Los Angeles stop-'n-stop traffic with no real drama.
I did indeed "butcher up" my vintage M/T intake to fit 4 Holley 4412 2 barrel carbs. Intending to put that on my straight axle Comet project.
