Author Topic: still smoking like a freight train  (Read 23598 times)
Re: still smoking like a freight train
« Reply #45 on: May 28, 2017, 08:52:02 PM »
ok,maybe later
« Last Edit: May 28, 2017, 09:15:04 PM by fryedaddy »
57 lima bean
« Reply #46 on: May 28, 2017, 10:19:52 PM »
"it is an auto,i had my modulator line clog up with oil-trans fluid not long ago"
 If thats the case...remove the line and plug the vacuum port to the modulator.Take it for a spin shifting manually ....(you won't have high gear) or just leave it in second,and see if it clears up.
« Last Edit: May 28, 2017, 10:21:38 PM by 57 lima bean »
« Reply #47 on: May 28, 2017, 11:09:46 PM »
i unhooked my modulator line today and blew threw it.it was clogged,but i did not get a chance to drive it today.i had the carb off today and i saw what looked like a drop or three of trans fluid in the bottom of the plenum.
« Reply #48 on: May 29, 2017, 06:03:30 AM »
Sounds like you found the source.  ;)
« Reply #49 on: May 29, 2017, 11:00:49 AM »
i just got back in the house after getting my car out for a while.i cleared out my modulator line and put a new mod valve on,put breather caps on my valve covers,threw away my pcv.NOT A TRACE OF SMOKE,NOT EVEN A PUFF WHEN I CRANKED IT.many thanks to all my FE brothers on the forum who helped me solve this problem,hats off
« Reply #50 on: May 29, 2017, 01:22:41 PM »
Awesome.....glad you figured it out.
« Reply #51 on: May 29, 2017, 02:54:56 PM »
thanks,Brent,you were the most help of all.thank you for your time and know how!
« Reply #52 on: May 29, 2017, 03:03:39 PM »
I wasn't any help dude, the guys screaming modulator valve were the heroes.
« Reply #53 on: May 29, 2017, 04:38:28 PM »
i pretty sure the pcv was sucking oil too.your the man who told me to get rid of it,plus you helped me eliminate other things,but thanks to those guys also.sometimes things take a while to figure out if im the only one thinking,so the more heads the better
« Reply #54 on: May 30, 2017, 06:14:28 AM »
Just to clarify though, a PCV is a good thing for a street engine.  If you can control the oil, it'd be wise to run it that way, it pulls moisture out, reduces pressure at part throttle saving gaskets, etc.  Of course if you have it in an oil bath, it's not too helpful, but may want to consider figuring it out on the street after you enjoy the car a bit.
« Reply #55 on: May 30, 2017, 02:23:31 PM »
its pretty much a racecar on the street.i change the oil every 500 miles anyway.its not like i take it on trips or drive it to work every day.i just get out and raise cane in it once in a while,never getting over 10 miles from my house.but i do plan on getting the oil under control and maybe hook the pvc back up
gdaddy01
« Reply #56 on: May 30, 2017, 09:45:37 PM »
glad you found it . I having been working on a 1945 willys jeep for an older fellow and the jeep has a stock pcv system on it . I did not know they went back that far . I guess in ww2 they did not want the enemy breathing bad air , before they shot them . thanks to all of our military in all of the wars and protecting our great country .
nhsohc
« Reply #57 on: May 31, 2017, 11:49:25 AM »
A little off topic:
Military used PCV equipment for fording, not pollution.  Ever follow a convoy of NG vehicles that has a gas powered truck in it?  Smell them 2 miles away.  Have a 1962 IHC built 5 ton (M139) w/ a 602 cid Continental which has a sealed PCV system in it; we use for a water truck.  Gets gallons per mile not MPG.  But will go almost anywhere on a jobsite without getting stuck.
gdaddy01
« Reply #58 on: June 03, 2017, 10:16:43 PM »
that is what I told the fellow I was working on the Jeep for . thought it might be for getting under water , not for smog , keep the water our of the engine , by not getting into breathers for the crankcase .
