Author Topic: Parts Headed to Spring Carlisle and the FE Reunion  (Read 3497 times)
Ntheogen
« on: April 15, 2017, 05:04:48 PM »
Heads:
1. CJ Heads: matched pair of CJ heads. 9M16 & 9M15. New bronze guides. Fresh hardened seats. Good thumbprint left. Freshly surfaced on all sides. Have been welded at
exhaust ports that isn’t to pretty. $700.
2. Complete set CJ heads mismatched 8L8 & 9J22. Never cut. Untouched $1000.
3. Matched CJ Heads. Bare set. 9A24 & 9B10. Rusted badly on one end. Valve cover surface pitted. $400.
4. 427 tunnel port heads. Ready to go. Have been decked a good bit. Ready to bolt on. $2500
5. Cobra Jet heads. 9C5 & 9B3. New bronze guides. New hardened seats installed. Work done by my local FE Machinist .Freshly surfaced on all sides. Good thumbprint
left. $950.
6. Matched set 406 heads 2E3 & 2E7. C2SE-C Heads. One head has 4 broken exhaust bolts. Both heads severely rusted on one end. $250.
Tires:
1. Pair of Cooper cobra radial GTs. Size P295/50R15. Like new – 50 miles on them $150.
2. Pair Cooper cobra radial GT P215/70R15. Like new. $75.
Crankshafts:
1. Fresh 1UA super cobra jet crankshaft with aftermarket dampener and hatchet. .010/.010. $1750
2. C4AE 427 Crankshaft fresh. .020/.030. $450.
3. 3U 427 crank. Needs turned. $200.
4. 428 crank 1U. Needs turned $200.
5. C5AE-6300-C. Cross-drilled $ crankshaft. Standard - $700
6. 1U 428 Crank. .020/ .020. Fresh. $400.
7. Scat 428 rotating assembly. Freshly Turned .010/.020 crank. Scat rods with ARP8740 bolts. H Beam rods. Forged pistons with rings. Hardly ran. $1300.
Blocks/Engines
1. 1J24 427 side oiler service block. .030 over. No repairs. $2500.
2. C5AE-A. Center oiler. Standard bore. 1 sleeve. No Welds or Damage. 4G9. $2500
3. 8G13 CJ block. Will need sleeves. $650.
4. 427 side oiler hydraulic block. .030 over. No repairs. $2750.
5. Standard bore 427 marine block in great condition. Solid lifter. $2750.
6. 1964 center oiler. .30 over. No repairs. $2500.
7. 428 Engine Complete .030 over A-Scratch Passenger Block
Edelbrock Aluminum Heads and Victor Jr Intake – H beam Rods with TRW Pop ups – Brand New Scat crank in the box – All roller valve train – New bearings in boxes –
Cometic Head Gaskets – New Canton Pan – Mallory Distributor – Everything except a carb – Disassembled for inspection - $8000
8. Complete 427 Tunnelport Engine .030 Side Oiler Short Block – Nice Heads & 2x4 Intake –BU/BT Carbs – Roller Rockers – Deep 427 Ford Racing Pan - $ Call Me – Could go
a few different ways with this.
Transmissions: Toploaders -
1. RUG AU-1. 1970-71 Torino 429 close ratio. Big in big out. Rebuilt. $1500.
2. Freshly Rebuilt -Short tail housing top loader for small block. C4ZR-A tail housing. Shifter location - rear. $1000.
3. Freshly Rebuilt - Short tail housing top loader for big block/small input. C4DR-A tail housing. Shifter location - rear. $1000.
4. Freshly Rebuilt - Short tail housing top loader for small block. 25 spline output. C4ZR-A tail housing. Shifter location - rear. $900.
5. Freshly Rebuilt – RUG AZ 1970 Boss 429/428 CJ top loader transmission. Rebuilt. C8AR-D Main case. C70r-A tail housing. $2500.
6. HEH D long top loader for 1964 galaxie. Close ratio. Excellent condition. $1000.
7. Freshly Rebuilt - Short tail housing top loader for small block. 28 spline output. DOZR-A tail housing. Shifter locatiom - middle. Rebuilt. $1000.
8. Freshly Rebuilt – RUG AE2 1969 Boss 429/428 CJ top loader. $2500.
9. Freshly Rebuilt - Short tail housing top loader. Small input for big block. Rebuilt. CZOR-A tail housing. Shifter locatiom - middle. $1350.
Misc:
1.   NEW - Holman Moody Webber Intake with Fuel Injection set up for an FE – Cost $4900 Sell for $3500
2.   Brand NEW Tri-power set up – Carls Ford Parts New Carbs in boxes – Mint Intake – Air Cleaner lid and base – New Fuel Log – New Linkage - $2500
3.   Old School PSE Hi-Riser Tunnel Port set up – Very nice intake adapter – Tunnel Ram and tops for Regular Holley’s and Dominator Flanges - $ 1800
4.   Standard Bore 427 Pistons on CJ Rods - $350
5.   9” Center Section 8G5 Date – 3.70 Ratio 28 Spline $250
6.   Long Nose FE Starter $50
7.   Very Nice Pair of 64 2 door Hardtop Galaxie doors. - $400/pair
8.   64 Galaxie Dash - $75
9.   64 Galaxie Fenders – One Really Nice Pair -$225 for both
1 Left Front with a little rust behind the headlights - $ 50
10.   64 Galaxie inner fenders – nice shape - $50 each or $75 for both
11.   64 Galaxie hood – Nice Shape - $200
12.   64 Galaxie Deck Lid – Little rust in the back lip but not bad - $150
13.   64 Galaxie Air Cleaner – Nice Blue unit -$50
14.   64 Galaxie Trim and interior Pieces – Call me
15.   NOS 67 Galaxie Rear Bumper – It wasn’t taken care off and its starting to peal in certain spots - $250
16.   FE Expansion tank – Painted Black $50
17.   64 Galaxie and Comet Bumpers – Cores and Driver Quality - $Call Me.
18.   1967 Glaxie LTD 2 Door Hardtop – Vinyl Roof – In decent shape – rust around the top area that is letting water in but overall a very sold car – Has lots of stuff done to it already – needs a driveline - $2250 – Call me for more Details
LOTS more but I am sick of typing - I work on cars for a living so I don't have to sit behind a computer... Ha
Most stuff is or best offer - I am trying to lighten the amount of stuff I have so give me a shout with an offer. I will also ship almost all of this.
Jack
540-664-44 one eight
jacksfordparts at gmail dot com
