Author Topic: What FE intake manifolds don't work with the lifter valley pan?  (Read 10778 times)
jholmes217
Re: What FE intake manifolds don't work with the lifter valley pan?
« Reply #15 on: January 27, 2017, 11:43:27 AM »
Thanks for all the responses folks.  My next manifold going on is a Ford medium riser 2x4.
Jeff
4 speed, 3:50 traction lock
Olympia WA. area
The Real McCoy
« Reply #16 on: January 27, 2017, 10:08:00 PM »
About a year ago I put together a 428 CJ block, C3AE-C heads (406 small chambers) and a 63 Low Riser 2 x 4 intake with a FelPro Gasket set.  None of the parts had been machined in any manner that would affect the intake installation, the intake was actually a NOS intake.  I had to bend the head gaskets on this combination to get the intake to settle down to where it needed to be to get the intake manifold bolts started.  Once I did that it fit up just fine.  I did use the corks gaskets on the china wall. At the time I really didn't want to start grinding on the intake as it was NOS, even though it would not have taken much to get it by the head gasket.  I think if I could have got all the intake bolts started it would have pulled into place but tweaking the head gasket made it go from difficult to really easy.  I guess my point is, at least in my case, even with all relatively virgin factory parts this can be an issue.
63 1/2 Galaxie 500
428 CJ Stroker with 427 2x4 Intake, 427 Long Exhaust Manifolds, Quick Fuel Carbs and TKO 600.
"What gets us into trouble is not what we don't know, it’s what we know for sure that just ain’t so."                            Mark Twain
