Author Topic: Tri-Power Intake  (Read 5395 times)
JimNolan
Tri-Power Intake
« on: May 08, 2012, 05:39:24 PM »
Guys,
   My buddy has a 64 Galaxie XL w/390 4sp. We just got back from this old man's barn where we heard there was some FE parts for sale. We ended up buying a FE 3 duce intake with correct 2436/37 Holly carbs and linkage. The old man was hard to deal with but we managed to get it for $400.00. The carbs he said had been rebuilt by a professional but never used afterward. My buddy is going to put the intake on his 300hp 390.
My question is. How do you limit the amount of flow on a setup like that. There's no way in h__ that 390 would take 1010 cfm at full throttle I wouldn't think. Surely he's not the only one that wanted to put this intake a carb setup on a low horse 390 for looks. What would you do to make this combination more streetable. Thanks, Jim
EDIT:   Sorry, should have researched it first. They flow 2V carbs differently. You end up dividing the total by 1.4 to get the usable CFM and that would be 728.
« Last Edit: May 08, 2012, 06:32:02 PM by JimNolan »
ToddK
Re: Tri-Power Intake
« Reply #1 on: May 09, 2012, 03:50:30 AM »
I'm running the 6V intake on my 390, and I have not had any problems with the intake being over carburettored. My 390 heads have been opened up a little and I'm using a Comp 270S cam, but otherwise it is set up like a factory 6V 390. Drives fine in a 63 4 speed Galaxie.
drdano
« Reply #2 on: May 09, 2012, 09:21:35 AM »
You can always jet too much carb down to what you need...pretty impossible to go the other direction though.   :D  I think you'd be fine.
