Author Topic: Spark Plugs for BBM heads?  (Read 15787 times)
Re: Spark Plugs for BBM heads?
« Reply #15 on: January 12, 2017, 12:36:27 PM »
Be very careful regarding items from KaleCoAuto. Their Roundtuit, for example, is far more complex than is necessary. I have a local source for them. They're wood, smaller, smooth to the touch, and have instructions imprinted on them. They are not only designated as roundtuits, but also as wooden nickels (on the other side). They're far more desirable, and they give them away!
You can buy all manner of fasteners in the same place!!
« Last Edit: January 12, 2017, 12:38:53 PM by cammerfe »
unclewill
« Reply #16 on: January 12, 2017, 01:01:03 PM »
Ok, after perusing the KaleCoAuto sight, I have found the blinker fluid and Jupiter belts I was too embarrassed to ask you guys about.  Many thanks!
428 GALAXIE
« Reply #17 on: January 12, 2017, 01:55:18 PM »
So everybody being so helpful here would somebody know any source of piston return spring.Ebey link would be nice.
Have any manufacturer made any rpm kits for piston return springs.
Mikko
« Reply #18 on: January 12, 2017, 02:15:22 PM »
I used to buy them from the same place I bought my cans of overspray from.  I'll see if I can dig it up.
bn69stang
« Reply #19 on: January 12, 2017, 04:55:13 PM »
I use the autolite  3924 s in my bbm heads , and unclewill ask away - thats what the forum is for and i think we all learn something every day .. Bud
CaptCobrajet
« Reply #20 on: January 14, 2017, 01:42:26 AM »
BBM for the street.......on pump gas.......NGK #BKR6E.  The best reasonably priced plug I have found for pump gas, and readily available.
Blair Patrick
mmason
« Reply #21 on: January 14, 2017, 10:01:10 AM »
Blair I am guessing that the part number should be BkR6ek.
Michael Mason
Red Lehr
« Reply #22 on: January 23, 2017, 07:22:23 PM »
What would you gap the NGK  or the Autolite 3924 plugs at ?
Red
« Reply #23 on: January 23, 2017, 11:55:34 PM »
I gap all my plugs at 0.035 to 0.038.  I have never seen a power increase on the dyno by running a larger plug gap.
« Reply #24 on: January 24, 2017, 05:59:44 AM »
Same here.  I actually run most of the AR plugs out of the box, just checking to make sure they weren't damaged in shipping.
