Author Topic: Oversized screws for stock fe adjustable rock rockers  (Read 5241 times)
63.5xl
« on: November 04, 2016, 08:26:57 PM »
Where can you find oversized screws for the adjustable or which aftermarket screw and locknut works for the stock adjustable rockers, 12 out of the 16 does not take anything to turn them.
Ranch
Re: Oversized screws for stock fe adjustable rock rockers
« Reply #1 on: November 05, 2016, 05:33:35 AM »
http://www.dscmotorsport.com/Cylinder/index.htm
under   Rocker Arms - Iron and Steel
Sounds like you'll be needing a whole set of 16 or you could just buy a set of 4 and see if they'll work for you
63.5xl
« Reply #2 on: November 05, 2016, 06:53:11 AM »
Thank you Ranch, I forget about DSC, I will call tgem
rockhouse66
« Reply #3 on: November 05, 2016, 07:07:44 AM »
I prefer converting to the jam nut arrangement with the Crane adjusters.  They are about $60 a set at your favorite parts place.  Just Google this;
Crane 99680-16 Shaft Rocker Arm Adjusting Screw
Jim
« Reply #4 on: November 05, 2016, 10:01:13 AM »
Me too, may add a smidge of weight, but in the end, you have an adjustment you don't need to worry about.
KMcCullah
« Reply #5 on: November 05, 2016, 11:32:51 AM »
I bought a set of adjusters from Alex's parts recently. I couldn't get them to thread into the rockers. The thread OD was waaaay too big. But I will say...they are hard as hell! I ruined a thread file trying to dress one down.
Kevin McCullah
63.5xl
« Reply #6 on: November 06, 2016, 09:17:34 PM »
I found the Cranes on Amazon for $55.59 with two day shipping and got them coming, thanks everyone for your input and help.
