Author Topic: 1967 fastback 485  (Read 125187 times)
6667fan
  • Every Second Counts
Re: 1967 fastback 485
« Reply #60 on: September 06, 2018, 11:50:02 AM »
Nice work Joe.
What is the peak hp and at what rpm?
I apologize if that was listed somewhere earlier and I missed it. JB
JB
67 Fairlane 500
482 cid 700/617
10.55@125.74 1.46 60’
« Reply #61 on: September 06, 2018, 06:23:22 PM »
Like I said I have the shift light at 6300, I didnt have it on the dyno but my assometer says
peak HP is 5800-6000. I believe when I short shift before the light comes on the car is faster.
With that being said I will be dropping the light to 61 or 6200. As far as how much horsepowrer it makes
I would have to say 525-550. I have been wanting to do a medium riser intake but Im already on a couple of
tracks radar about a cage and I would really like to not do that. I will be putting on my exhaust the next time I go
so I can see what it runs just the way it is on the street
« Reply #62 on: October 14, 2018, 06:47:58 PM »
So last hurrah at the track today. As most have been following in the MSD post I have been having
A weird problem and today it wasn’t bad today had a slight hesitation 1.576 60 ft instead of my
Usual 1.55/1.56. Now I ran my exhaust today so this is how I run it on the street. First pass
11.401@118.36 so I thought ok leave it alone and see what the next pass brings. Second pass
11.402@117.80 so seems good to me I dialed a 11.39 so if I cut a good light and don’t red light
Should be good. So I go up do my burnout and stage the first light and the staging guys knocks on my window and tells me I can’t dial a 11.39 because I don’t have a rollbar. First time I have been called on that. So they put my dial in at 11.50 it flustered me alittle being last minute, we’ll took off and was ahead and they were playing catch up and they were coming fast. So I got off the car about 50 to 75
Ft before the first set of cones and crossed the stripe about a car and a half in front which I should have slowed up more because I ran 11.488@108.10. So my fault I lost just like the FE reunion in the finals. Well even though I went home early had a good year thanks to all the help from all of you guys.
« Reply #63 on: October 14, 2018, 07:46:46 PM »
Sounds like a good way to end the season - even if you did get bounced.
Always OK to be able to say you were scolded for being "too quick"
FElony
« Reply #64 on: October 17, 2018, 11:26:57 PM »
Not if that's what she said.  ;D
« Reply #65 on: October 18, 2018, 01:28:38 AM »
 :o ;D
« Reply #66 on: October 13, 2019, 06:08:18 PM »
So I went to the track today and the only difference between last year and this year was an even swap low riser 2x4 to medium riser 2x4. So got there and took my exhaust off and air cleaner off. Gave the car a once over including air in tires. Went up and did a good burnout , now I haven’t been to the track all year because of my back surgery and I only drove the car about 200 miles all season. Got up to the line and took off 60 ft time is usually 1.54/55 my best was a 152 this pass was a 147.9 I could tell that it was stronger it seemed to be pulling a little harder. I hit second gear and now I can feel it going nice and I’m thinking I got my 10 second pass in the bag. Well just as I was going to hit 3rd it sort of flattened out still moving but not pulling like it was, stayed in it but it just felt weird not like a miss or lacking fuel so I made it through the pass. Let off the gas and stepped on the brakes and thought I didn’t have any brakes but what it was was my throttle stuck so I tried to fiddle with the throttle for a second and was on the brakes like crazy. Brakes smoking and everything. By the time I shut the ignition off there wasn’t much real estate left, and the brakes were so overheated that they weren’t working that great. Well the end of the track was approaching and I’m still doing 80 miles an hour and need to make a left banking turn. Needless to say I didn’t make it and trying to make the turn went over the first dirt mound. I ramped it all four wheels off the ground it did probably slow me down to 40/50 miles an hour by the time the car hit the ground the second mound was coming. Ramped that mound which slowed me down but while I was up in the air I looked ahead and there was a big red dump truck. Now I’m thinking if I don’t do something I’m gonna hit this thing doing somewhere in the ballpark of 30/40 miles and hour so I cut the wheel all the way to the left while the car was in the air and when the nose came down mostly on the pass wheel the rim dug into the ground and made an abrupt left turn (thank God). The car came to a halt about 75 feet away covered in dirt all the way up to the carb. We’ll talk about scared shitless. I crashed the lower valence the pass fender has a little bend in it and some suspension stuff is bent. Will look at it in a couple of days I’m just to upset to find out any other bad news. I will keep everyone informed but a scary day for me. Oh anywa 11.09 @ 120.20 . So when I popped the hood I found the carb gasket to air cleaner jammed down the Venturi and that’s what made the throttle stick. So my fault. That’s why it started to lay down after hitting second gear.
plovett
« Reply #67 on: October 13, 2019, 07:17:35 PM »
Sorry to hear that.  Glad you are okay.   Sounds like you have 10's in the bag with some repairs.
« Reply #68 on: October 13, 2019, 07:22:29 PM »
Ouch :o :o sorry to hear that hows the back after all jumping mounds?
« Reply #69 on: October 13, 2019, 07:45:15 PM »
Starting to be a little sore. Not bad more my pride from being an idiot forgetting the gaskets.
64PI
« Reply #70 on: October 14, 2019, 07:35:24 AM »
Glad to hear your okay and the only thing that's hurt is your pride and the car, they can both be fixed. I have a '64 Galaxie with no cage or bar knocking on the 10.99 door. I'm making the decision to slow the car down since I don't wanna put a cage in it. I'm building a purpose built drag car with a cage and all the proper safety gear. It's fun to brag about having a fast street car but a lot can go wrong at 120 mph especially with no bar and lap belts.
Fred
Bolted to Floor
« Reply #71 on: October 14, 2019, 08:44:14 AM »
That sounds like a wild ride I never want to take!! Glad to hear you are ok and the car is mostly ok. Was hoping to see April fools or “then I woke up”!!!
« Reply #72 on: October 14, 2019, 01:14:33 PM »
Yes Paulie I think im knocking on the door and would have had it if the gasket didnt get sucked in there.
Good idea building another car for racing but not in the cards for me money wise Fred. I just want to see 10s then gonna run 11.50s and be consistant.
Hey Heo the back is alittle soar but thank God not in my surgery spot.
John while it was happening I was trying to stay calm so I could think. Definetly wild. And i wish it was a dream, I will be going there to look at car tommorrow so hopefully its not to bad. I will keep you informed.
« Reply #73 on: October 14, 2019, 06:11:43 PM »
Dang, Joe, sorry to hear about that. It sounds like you're lucky the car didn't grab and roll over when the tire dug in. It also sounds like you would have gotten that 10 second time slip for sure. Apparently that MR intake was making a real difference. Just glad that you are ok and that the car wasn't hurt badly. Hopefully, nothing on the frame was hurt.
« Reply #74 on: October 14, 2019, 07:18:55 PM »
Yeah Doug that’s what I’m worried about, I guess I will be doing some measuring. To bad there aren’t any specs that I can measure against
