Author Topic: TCP rack&pinion on FE mustang  (Read 16470 times)
rcodecj
Re: TCP rack&pinion on FE mustang
« Reply #15 on: April 30, 2012, 02:54:09 PM »
Looks like the Canton 13820A oil pan might do the trick:
https://www.cantonracingproducts.com/cgi-bin/commerce.cgi?preadd=action&key=13-820A
Much better fit at the back of the sump than the Moroso 20608
http://www.moroso.com/catalog/categorydisplay.asp?catcode=11685
Stock pan (Cory's picture:
« Last Edit: April 30, 2012, 02:57:15 PM by rcodecj »
MustangGT
« Reply #16 on: May 02, 2012, 04:59:38 AM »
I have just finished(yesterday) installing a TCP power rack on my FE powered '67 Mustang Fastback.
No problems whatsoever. I am running stock exhaust manifolds and the clearance between the exhaust flange and valve body on the driver side is tight but should be ok. Stock pan with plenty of clearance also when using both the thick and the thin incluced shims.
I still have some other stuff to finish like putting in the windshield and bleed the hydraulic clutch so no driving experience yet.
Regards
Morten
