Author Topic: Long Rod FEs  (Read 21092 times)
ericwevans
Re: Long Rod FEs
« Reply #30 on: October 05, 2016, 03:24:55 PM »
Good read, and very similar.  I'm starting with a 360 block, iron heads, 288/300 duration .580 lift on the cam, Jays intake adapter, and (gasp) a Weiand Tunnel Ram with a pair of 500 CFM Edelbrock Thunder AVS carbs.  And I'll attempt to drive that junk on the street.
I'm still finalizing the combination but that should be close to final.  Buying the short block in November so stuff will start becoming final then.
Eric Evans
1965 F-100, 352 FE, Tremec 3550
1960 Falcon, 306 SBF
