Author Topic: Stud Tightening Technique  (Read 14692 times)
Autoholic
Re: Stud Tightening Technique
« Reply #15 on: September 28, 2016, 11:38:23 PM »
So it sounds like finger tight is the best method. The whole point for studs in the first place is to be able to torque down a nut from a relaxed state, so you only apply a vertical clamping stress. Bolts, when torqued down, also have a twisting force, which results in uneven loading because the tension isn't applied with the threads in a relaxed state. So you don't need to torque down a stud, you're relying on the strength of the threads anyways when torquing down a nut.
~Joe
« Reply #16 on: September 29, 2016, 02:08:33 AM »
I think comon sense is always needed ;)
You dont "torque"the stud with a ball bearing
Just snug it down thight and you ofcause have
To chose the right size on the ball. Big enough
So the stud dont bottom out in the threads
And small enough so the stud dont engage
Enough threads
GJCAT427
« Reply #17 on: September 29, 2016, 05:22:19 AM »
Jay, I got mine from MAC tools. I think Snap on carries them also.
« Reply #18 on: September 29, 2016, 07:24:31 AM »
Part of the answer lies in what the stud is being used for. For main studs, you wouldn't want to torque them. For low load areas, where the stud is meant to be a more permanent fixture, especially during disassembly, then tightening or torquing may be called for.
« Reply #19 on: September 29, 2016, 09:02:01 AM »
Thats true... Use comon sense
« Reply #20 on: September 29, 2016, 09:33:02 AM »
Those sockets that Bill posted are pretty cool; where do you buy those?
Jay - They are made by a company in the UK called Sealey.  There may be an equivalent in the USA, but you can buy them on Amazon UK and get them delivered here:
https://www.amazon.co.uk/Sealey-AK7232-Extractor-Go-Through-Ratcheting/dp/B004ZFD0KI/ref=sr_1_14/254-0643964-6701638?s=diy&ie=UTF8&qid=1475159437&sr=1-14
C6AE
« Reply #21 on: September 29, 2016, 11:07:51 PM »
Snap on has several variations, it was so long ago when I bought mine I was still working on Flatheads!
They are pricey today...
https://store.snapon.com/Cam-and-Wedge-Type-Stud-Removers-C675444.aspx
westcoastgalaxie
« Reply #22 on: October 02, 2016, 09:15:42 PM »
Since it was brought up I'll add to it. Chasing threads, I just recently discovered thread chasing taps. I had always used bottoming taps or starting taps in a pinch. Never cared for them because at times it deformed the threads and made the hole sloppy. But man what a difference thread chasing taps made. For those that don't have them, get a set.
