Author Topic: Has anyone tried a cable clutch linkage conversion?  (Read 12863 times)
ewo357
« on: September 14, 2016, 02:46:09 AM »
I'm converting my 66 Galaxie from auto to manual but not having much luck finding the clutch linkage. Has anyone tried a cable linkage? Mustang Steve says he has a kit that would work.
What years are the same as 66 for the factory linkage?
Re: Has anyone tried a cable clutch linkage conversion?
« Reply #1 on: September 14, 2016, 04:59:40 AM »
McLeod makes them.
Personally, I'd rather have a good old-fashioned mechanical linkage.  Next to that, I'd do a master/slave (not hydraulic TOB) setup.
« Reply #2 on: September 14, 2016, 07:38:11 AM »
Curious Brent why you don't like the hydraulic set up.
« Reply #3 on: September 14, 2016, 09:26:32 AM »
Years of experience has shown me that hydraulic throw out bearings have the greatest risk of leaking....
« Reply #4 on: September 14, 2016, 12:41:47 PM »
I also much prefer the factory style mechanical clutch linkage. My Fairmont drag car came from the factory with a 4 speed, so it was already equipped for a cable clutch mechanism, but I chose to make up a mechanical setup, closely copying the clutch linkage in my 74 F350. It works great. My 85 Mustang drag car, and now my Fairmont with the SB Ford engine have cable clutch linkage, but I much prefer the feel and operation of the mechanical linkage. Plus even with the SB Fords, it takes creative routing and securing to keep the plastic cable away from  the headers, a much larger FE would be a fair bit tougher. I know a few guys that have tried hydraulic throwout setups, none seem very happy with them.  Between trying to stop leaks, getting the bearing shimmed properly, and again, routing the hyd. line while avoiding the headers, caused numerous headaches. Both my 2010 Ranger and 1999 F350 are factory equipped with hydraulic throw out bearings, and seem to work fine, but both still have the original clutches. I understand that when it comes time to replace the clutch(es), they can be a PITA to replace and get working properly, especially bleeding the system.
« Reply #5 on: September 14, 2016, 01:46:06 PM »
Thanks guys.
I'm stuffing an FE in a '66 stang and am trying to come up with a reasonable system.
« Reply #6 on: September 15, 2016, 07:49:44 AM »
Personaly IF i do a new linkage  i do master slave hydraulic
ewo357
« Reply #7 on: September 17, 2016, 12:50:38 PM »
McLeod makes them.
I don't see anything on McLeods web site....?
What years factory linkage will fit my 66 Galaxie?
ewo357
« Reply #8 on: September 17, 2016, 12:58:26 PM »
How does one fab their own mechanical linkage? Is the reason that no one makes these parts because it is simple enough to do yourself??? Why is clutch linkage so hard to find when anyone can buy anything on the Internet? Am I not searching with the right words?
« Reply #9 on: September 17, 2016, 05:07:10 PM »
Im not sure but i think 65 to atleast 70 fit your 66
« Reply #10 on: September 17, 2016, 07:31:40 PM »
Here you go. Start clicking on the images...................
https://www.google.com/search?q=1966+ford+galaxie,+clutch+linkage&rlz=1C1SAVS_enUS541US568&espv=2&biw=1097&bih=551&source=lnms&tbm=isch&sa=X&ved=0ahUKEwj2xLLg1JfPAhWn44MKHV7SClMQ_AUIBygC&dpr=1.75
ewo357
« Reply #11 on: September 18, 2016, 01:28:42 PM »
Yep, your Google search came up with Fairlane linkage, corvette linkage, Chevelle linkage, mustang linkage, nova linkage, universal hydraulic linkage but no mechanical linkage for a 66 Galaxie.
« Reply #12 on: September 18, 2016, 03:57:05 PM »
Yes, and I knew that but.....fabrication of a few parts, adaptation of Fairlane pedals and mosty off-the-shelf unmodified Ford parts will get you what you need.  Hot rodders adapt what they need to get the job done.
ewo357
« Reply #13 on: September 18, 2016, 05:09:19 PM »
I have the correct pedals for my Galaxie. It's just the linkage that is eluding me...
« Reply #14 on: September 18, 2016, 05:17:36 PM »
Hey ewo357 why don't you put a wtb (want to buy) thread in the classified section of the other FE forum. Lots of traffic there with lots of knowledgable guys.
http://www.network54.com/Forum/75943
