Author Topic: oil filters  (Read 22559 times)
Richard F
Re: oil filters
« Reply #30 on: September 20, 2016, 07:07:42 PM »
The Baldwin B253 I have used myself on several engines and have had no problem at all.  It is a heavy duty filter and has a high burst rating.  My FE ran about 125 psi cold so I used this as well as an FL1HP, 51515R Wix, or 1515R Napa.  I trust Wix, NAPA, Baldwin, and Motorcraft.  That's it for me.  JMO.
Qikbbstang
Re: oil filters
« Reply #31 on: September 21, 2016, 07:41:36 PM »
Richard 125psi COLD is oblivious to HOT but the 67 427 FoMoCo shop manual lists the oil pressure as 40-55psi @ 2000rpm HOT
            man I am wondering if that is some serious torque on the distributor drive gear & pin?
Re: oil filters
« Reply #32 on: September 21, 2016, 09:13:33 PM »
K&N pure power billet reusable or systems one ?
Richard F
Re: oil filters
« Reply #33 on: September 22, 2016, 07:40:36 PM »
I built it in 1997 and have never had a problem.  It is a HP HV pump.  I just (usually) let it warm up some before I got on it.  Hot, it would run around 100 psi at higher rpm.
