Author Topic: Building a custom shroud, out of broken crap?  (Read 4852 times)
428Marauder
« on: August 07, 2016, 03:54:13 AM »
So, I had an idea.
428, runs great, little hot in hot weather, and I live in Arizona. People here have been tremendously helpfull, but despite the aluminum radiator, electric fans, trans intercooler, she still runs a little hot. 190ish in hot weather. So, my original fan is only running with the like 8 inch metal plate that says "CAUTION - FAN", ya know the original metal 1965 "shroud" . I use that as a guide for how my hood shuts. That is top clearance. Pic attached.
Now, I had a plastic shroud. I still have parts of it. I could never get it mounted right. Several times it got mauled by my fan. I have the bottom half of it though. It's pretty beaten up, it fits. A new one is like $85 ... I know, but I am cheap. Maybe the bottom half ... better than nothing at all?
http://m.imgur.com/zh8DeYw
Maybe, I can create a flexible, adjustable shroud, or a shroud made of multiple pieces, so you can remove or adjust the shroud without taking the fan assembly off. Patent it, get rich.
« Last Edit: August 07, 2016, 04:00:56 AM by 428Marauder »
Re: Building a custom shroud, out of broken crap?
« Reply #1 on: August 07, 2016, 12:22:37 PM »
my 428 was running hot this summer,turned out to be the bottom rad hose squeezing shut when it got hot.i put a wire in it,no more high temps.i just happened to look at it while revving the engine and saw it flatten out.
« Reply #2 on: August 07, 2016, 12:31:15 PM »
[/quote]
I'd forget the rich idea! Nothing wrong with cheap I say.
I'd do all I could to enclose the fan 360 degrees to maximize the pull thorough the radiator or as much as one can. I did see a fella's car where he took a big round aluminum mixing bowl (no kidding!) cut the bottom out and pop-riveted the round section to a flat sheet of aluminum with a matching hole cut out. Voila! A very pro looking fan shroud.
« Reply #3 on: August 07, 2016, 04:04:05 PM »
Why is 190* considered hot?  That is within normal operating temperatures.  Warm weather 185* TS, cold weather 195* TS.  If you have anything else, you are cycling the water too quickly.  Also a 13-17# radiator cap will be a must.  I drove my 428CJ for five years in Phoenix with stock 195* thermostat, AC, PS, etc.
428Marauder
« Reply #4 on: August 10, 2016, 03:04:41 PM »
[/quote]
Ha! Cool idea!
Re: Why is 190 too hot? It's not really, in this weather. She does seem to knock a little sometimes, like going up a hill after sitting at a light. wouldn't 180 be better?
