Author Topic: 67 Mustang strip/Street project  (Read 15964 times)
Russ67Scode
Re: 67 Mustang strip/Street project
« Reply #15 on: August 07, 2016, 06:36:16 AM »
The 428 is not a CJ block will that change this thought path?
Thanks
Russ67Scode
« Reply #16 on: August 09, 2016, 06:20:38 AM »
Blair here is the intake I really want any inside leads to this one
http://bearblockmotors.com/bbm-fe-intake-manifold/
Thanks Russ
« Reply #17 on: August 09, 2016, 08:56:12 PM »
Unless you have 7000+ rpm on your mind, the crossbolts may be a good upgrade but not required.  The 390 blocks split cylinders vertically when overpowered.  The mains in a three web 390 will generally live longer than the cylinders will.  Every high HP 390 I have ever done eventually split a cylinder.  Only one pulled the main apart.  I think 600 hp is the limit of the 390 cylinder cores.  I think the 428s will go higher reliably.  If I were you, why not sleeve the one hole a nice dry sleeve, and then just hone the others.... then buy pistons to fit the bore....less than a crossbolting exercise, and a good foundation....
So Blair, not to hijack the thread but,
What's your thoughts on a 428 A block like I'm putting  together ?  Cross bolt pro-gram mains, design concept's main stud girdle, .010 over bore, 1 sleave, 3/4 block fill, . If I did my homework and it's properly built do you Think this block could live for a while at 7800 rpm and 725hp ?
CaptCobrajet
« Reply #18 on: August 09, 2016, 10:04:29 PM »
Russ,  those intakes are in production now.  I have the prototype here now.  They will be nice!
KB, you will definitely need crossbolts and studs for your goal, in my opinion.
Blair Patrick
« Reply #19 on: August 09, 2016, 10:15:50 PM »
She's cross bolted and girdled, filled and all cylinders are over 125 min thickness at finished bore. I'm feeling good about it.
Russ67Scode
« Reply #20 on: August 22, 2016, 01:05:17 PM »
Now I find this post !  is it too late to swap or do you think it would be better to stay with the victor with FI built in ?
« Last Edit: August 22, 2016, 01:08:14 PM by Russ67Scode »
