Author Topic: Installing a solid cam  (Read 12529 times)
Re: Installing a solid cam
« Reply #15 on: May 29, 2016, 08:35:22 PM »
Earlier I mentioned there was a benefit with having oil at the lifters because you could use EDM lifters.  However, I have never HAD to use them, including both of my own toys.  So as Jay mentioned, if you want a little margin of safety, sure, but they sure aren't a requirement
machone
« Reply #16 on: May 30, 2016, 12:35:49 AM »
Ok, thanks guys.
chris401
I Did Not Plug Oil Gallies On My First Swap
« Reply #17 on: May 31, 2016, 03:34:31 PM »
And have not met anyone that had this problem in a FE. My experience is very isolated but possible. I picked up a 64 solid lifter 390, overhauled it  and ran it with a stock oil pump fine. The engine it replaced was a hydrolic 67 390 that ran fine with a stock oil pump. When the early 390 windowed I had the cam reground with the same type new mushroom lifters and transfered everything to the 67 block. Now I had 2 psi at idle, same with a new gauge. W60 and an HV pump got me up to 45 psi idling in summer DFW traffic. Not sure if the lifters are a little small, cam circle too low, lifter gap too low or? When I detuned it with a hydrolic cam I left the HV pump in ran 10W30 and now had 63 psi idling in traffic. A forum member ran that C7 block for a while with no oil pressure issues either. Still have the solid cam and lifters. Some day I'll mic the old lifters against the newer comp mushrooms I have shelved.
