Author Topic: TnD street/sportsman rocker shaft dia  (Read 6625 times)
« on: May 23, 2016, 04:07:48 PM »
I have ask this a few times with no response. I know that atleast a few of you guys must have or use the TnD street rocker setup. I'm just wanting to know the dia of the shaft.
Anyone ?
XR7
Re: TnD street/sportsman rocker shaft dia
« Reply #1 on: May 23, 2016, 04:15:15 PM »
I don't have a set and have never measured them, but... I asked the same question when they first came out, and if I remember correctly... the "street T&D"  are .750 diameter shafts, the T&D Race sets I own and have run, they are .625. Jesel are .562 and the stock FORD I think... are .840 (that might not be correct).
Posi67
« Reply #2 on: May 23, 2016, 09:43:04 PM »
And just for comparison... the Ersons are .682 so if as I suspect you were hoping to find a replacement shaft, we're both out of luck unless someone has spares for sale.
« Reply #3 on: May 23, 2016, 10:09:18 PM »
Yes, T&D street is .750"
Erson have an 11/16" shaft or .6875".
Harland Sharp standard bushed are .840"
Harland Sharp needle bearing are .875"
Harland Sharp "new" style bushed are .750"
« Reply #4 on: May 24, 2016, 05:23:28 AM »
Thanks guys, wondering which .750 shafts are more readaly available. The Harland sharp or the TnD.
« Reply #5 on: May 24, 2016, 09:39:39 PM »
FWIW, the T&D 3/4" shaft is hollow like the Erson for standard oiling, whereas the Harland Sharp 3/4" is solid.
« Reply #6 on: May 24, 2016, 09:59:43 PM »
Thanks.
