Author Topic: SINister EDition '66 Comet Caliente  (Read 60071 times)
SE2839
Re: SINister EDition '66 Comet Caliente
« Reply #45 on: August 17, 2025, 03:13:20 AM »
Hello group, I am back!
When I stepped away in 2014 I had pulled the 445 stroker, upgraded the modified C6AE-R heads to a set of ported BBM heads which were new to the market at the time. The engine was assembled and the new front suspension had been installed when life got in the way and the project was mothballed, other interests would come n go, and soon 11 years would have past.
So after years of procrastination the engine and chassis have finally been reunited, and the dyno results are in. WerbyFord, I hope that you find this thread, you should know that your Gonkulator was dead-nutz accurate! You'd predicted an increase from 465 to 539hp at the crank and 365hp at the tire. The actual results (drum roll) an increase from 309hp with the iron heads to 366hp at the tire with the BBMs.
The aftermarket support for the FE enthusist has grown and my build with its factory block and BBM heads has become entry level but I invite you to read this thread from the beginning to follow the transformation.
New for 2025-
Cragar SS wheels have replaced the Torque Thrust D's with 15x10s wrapped in 295/55R15 ET Street drag radials now filling the rear wheel wells.
A whole new altitude. Moving away from a lowered sleeper appearance towards that of a period correct R-code tribute.
« Last Edit: August 19, 2025, 11:54:14 PM by SE2839 »
1966 Mercury Comet Caliente, 445 stroker, BBM heads, Comp roller cam, Harland Sharp roller rockers,  Blue Thunder 2x4 intake, QFT 750cfm carbs, FPA headers, Wide Ratio C6, Hughes 3000 stall, Gear Vendor O/D, 9" Detroit Locker w/456s,
Calverts, Open Tracker, Crites
475fetoploader
« Reply #46 on: August 17, 2025, 09:26:54 AM »
Good for you! That’s great.  I wasn’t familiar with your build, I will go back to the start and chit out.
1967  519 c.i.  TKX 5 speed
