FE Technical Forum
PCV for a low riser 2X4
Topic: PCV for a low riser 2X4 (Read 2961 times)
cattleFEeder
Full Member
May 03, 2016, 06:28:42 AM »
Should I try getting a pcv valve hooked up to vent tube on my manifold, I have pentroof valve covers? Right now it just vents out under the car. I was going to just hook up to the rear carb , will that work?
Last Edit: May 03, 2016, 08:29:32 AM by cattleFEeder
Remember, RPM is your friend
FE Technical Forum
