Author Topic: 427 Center Oiler Block - early date code  (Read 4189 times)
JAKES66
« on: April 11, 2016, 05:17:23 AM »
For sale: An original Ford early date coded (3B5:3) 1963 427 FE engine block. Needs a good cleaning from light surface rust on all surfaces. The block has had no major blowups or welding repairs, but it has had (1) sleeve installed in the #8 cylinder. Cylinder sizes currently measure 4.266" +/- .001". The bottom of cylinders #1 and #5 have small nicks in them (possibly from a connecting rod failure?) but there are no other signs of damage. All main caps, spacers and bolts are included.
Also included is the oil pressure bypass/relief valve and spring already installed. I am asking $2900.00 or best reasonable offer. I'm located in Singers Glen, VA 22850. For no additional cost I can palletize and load a truck from work where we ship out freight all the time, but you'll need to make the trucking arrangements. I can deliver for free to the 2016 Spring Carlisle or the 2016 FE Race and Reunion in Beaver Springs, PA.
Best to contact me via email by sending a private message, but you can also call or text (540) 820-1514.
http://i1344.photobucket.com/albums/p644/jmumbauer/Mobile%20Uploads/20160410_174823_zpsqovoni8m.jpg
http://i1344.photobucket.com/albums/p644/jmumbauer/Mobile%20Uploads/20160410_175436_zps3ke2bypm.jpg
http://i1344.photobucket.com/albums/p644/jmumbauer/Mobile%20Uploads/20160410_175418_zpsfimm6rvr.jpg
http://i1344.photobucket.com/albums/p644/jmumbauer/Mobile%20Uploads/20160410_175405_zpsk2v5blsz.jpg
Jake Mumbauer
-1966 Galaxie 500XL Hardtop  390 C6 3.70 Tracloc   Soon with upgraded 390 and HEH-CC toploader
