Author Topic: Part found after assembly, is it important?  (Read 3345 times)
sideoilercat
« on: March 09, 2016, 03:26:49 PM »
Don't remember where I took this from, I think it was behind the timing chain. It's a service short block side oiler and I have blocked off the lifter galleries so maybe it can have a solid plug in it's place which I'm pretty sure I replaced it with. I just got a little worried when I found it after I finished the short block.
Thanks JK.
67 Cougar GT 427 M riser side oiler "ALLEY KAT"
70 Cyclone GT 429 CJ
82 Merc Capri 5.0 bought new
Qikbbstang
Re: Part found after assembly, is it important?
« Reply #1 on: March 09, 2016, 07:30:23 PM »
My W.A.G. perhaps from the lifter galley side up near the distributor drive on a Hyd (sideoiler) that was/is run as solids, to keep relieve oil from building up in the unpressurized oil galley's .   If something that large was used to meter oil it'd have near zero oil pressure.
JMHO
