Author Topic: New Project  (Read 37820 times)
Re: New Project
« Reply #15 on: July 08, 2012, 09:38:48 AM »
Looks great, Dean.  Love those headers!
Re: New Project
« Reply #16 on: July 08, 2012, 10:04:56 AM »
Same here, love it, and the headers make it even better!
DEANs427
Re: New Project
« Reply #17 on: September 18, 2012, 04:32:28 PM »
got the car to move under its own power and stop so took it to the MN Ford Performance club show last Saturday at Midway Ford. had lots of interest. new pic attached....
1956 Ford Gasser 427FE
1966 Fairlane
1966 Bronco supercharged
DEANs427
Re: New Project
« Reply #18 on: September 18, 2012, 04:36:32 PM »
another pic,
1966 Fairlane
lovehamr
Re: New Project
« Reply #19 on: September 19, 2012, 01:54:13 PM »
I dig that!  Bet it sounds badazz to! :)
Re: New Project
« Reply #20 on: September 20, 2012, 08:05:01 PM »
Like it alot and the one in the background to
hondakilla98
Re: New Project
« Reply #21 on: September 24, 2012, 07:38:15 PM »
Very cool car, It's nice to see a 56 ford gasser. I picked up a straight axle to do that to my 56 club sedan a few years ago, but I changed my mind and I'm going to lower it instead.
DEANs427
Re: New Project
« Reply #22 on: October 17, 2012, 04:47:13 PM »
though not close to race-ready yet, I took the car to BIR for their final race day of the season, mainly to get a road test of the work done so far. I regarded every system on the car to be suspect since I had only moved the car under its own power a few hundred feet previously. Ambient temp that morning was 40* and was informed by tech that they would only be running 1/8 mile and not until track temp was up to  minimum safety level. that was ok by me, after passing tech, I proceeded to drive around the pits and return road  for the next 30-40 minutes. most systems checked ok, carbs were a little fat but that was fine for today, I purposely set the throttle so it would only open about 2/3 of the way. finally got to make a pass about 1pm.
Traction was non-existant in 1st and 2nd, (i had not done any work on the rear other than set pinion angle and clamp the springs on the 9" that came with the car). coasted thru traps at 70 mph, the steering seemed to be ok but would take some getting used too. the guy at the time slip shack said I had left a fair amount of dirt and debris at the starting line! that was understandable considering the car had been sitting in the desert for years. After blowing air into the frame rails and taking with some other drivers in the pits, I went for a second pass, in the right lane this time where traction seemed a little better.
Up in smoke again off the line, short shifted to 2nd and Bang! car wanted to make a right turn, stopped and check for and leakage, none, so idled off to the trailer. day was finished with a broken left axel. Overall I considered a succesful day, look forward to next year!!
1966 Fairlane
DEANs427
Re: New Project
« Reply #23 on: October 17, 2012, 04:50:29 PM »
axle pic
1966 Fairlane
Re: New Project
« Reply #24 on: October 18, 2012, 08:39:08 AM »
Looks like a stock axle?  28 or 31 spline?
Re: New Project
« Reply #25 on: October 18, 2012, 06:32:42 PM »
Wild, it even broke the cam!!
DEANs427
Re: New Project
« Reply #26 on: October 19, 2012, 09:41:33 AM »
the axles were 28 spline with "MW" stamped on the flange. the history on them is unknown as they came with car but there is evidence that the car was racer before the gasser conversion was started.
the cam in the background was from a previous episode.....
1966 Fairlane
Re: New Project
« Reply #27 on: October 19, 2012, 12:01:28 PM »
A M-W would indicate a Mark Williams axle, yet it doesn't look like one of their more modern 'unbreakable' axles. I'd venture it's an old M-W axle (like in very old!) that's not nearly as strong, 28 or 31 spline notwithstanding, as their newer stuff.
http://markwilliams.com/axles.aspx
« Last Edit: October 19, 2012, 12:04:46 PM by machoneman »
DEANs427
Re: New Project
« Reply #28 on: March 20, 2013, 08:14:43 PM »
With Test-n-Tune only 1 month away I am beginning the upgrade of the differential to handle 21st century FE power level.
housing is back after reinforcement and straightening, pumpkin, axles and ladder bars ready to go in.
now if only the snow makes a rapid exit !
1966 Fairlane
DEANs427
Re: New Project
« Reply #29 on: March 20, 2013, 08:22:49 PM »
more pics
« Last Edit: March 20, 2013, 08:31:25 PM by DEANs427 »
1966 Fairlane
