Author Topic: worn cam  (Read 12496 times)
Re: worn cam
« Reply #15 on: February 23, 2016, 07:27:09 PM »
Well, you'll know in a hurry when you yank the heads, bench them and pour some kerosene, lighter fluid or paint thinner down an exhaust port or two. Ditto for a few intake ports. Bet the exhausts leak about as fast as you can pour.
Btw, this is why many of us here often recommend a leak-down test as well. Aside from telling if the valves, seats etc. are bad, the two tests (leak-d and compression) may prove that the rings, ring lands and pistons are still good allowing you to skip a total teardown for now.
Funny cause I do remember a local fellow who was pretty good with cars but kinda' dumb in many ways too. He added freshly rebuilt heads to an engine that really needed a ring job if not a total overhaul. Well, it ran better but man that partially refreshed engine blew oil everywhere, in large quantities, out the breathers, exhaust pipes and more! The dipstick was literally blown up off it's seat about 6" every time he hit the throttle! Gene Saubert, R.I.P.!
390owner
Re: worn cam
« Reply #16 on: February 28, 2016, 06:04:34 PM »
I was looking at  my 390 today and saw something on the intake I have not payed attention before and it may be nothing but I wanted to see what you guys think. There are two spots on my intake where there is no oil. It looks like it gets hot and keeps the oil burnt off from these two spots. What do you think here is a couple of pictures.
Re: worn cam
« Reply #17 on: February 28, 2016, 06:18:55 PM »
That is the exhaust crossover.
There is a chambers under the intake where the exhaust gasses heat
the intake. To keep the carb warm in the cold parts of the world.
Looks normal.
390owner
Re: worn cam
« Reply #18 on: February 29, 2016, 07:22:14 PM »
Ok  I was not sure. I priced a complete rebuild today. He said a hot cam and some head work I was looking at around 325-350 horse. That is the stock heads. He said it would be about 2200 dollars. He was also going to balance it with some stronger rod bolts.
390owner
Re: worn cam
« Reply #19 on: April 08, 2016, 08:53:15 PM »
Would I help my engine if I just re ringed it and ground the valves with new cam and bearings or should I just take it to a machine shop
abyars
Re: worn cam
« Reply #20 on: April 11, 2016, 10:54:07 AM »
You mentioned in your rebuild quote a "hot cam".  Be careful when building a towing engine, you don't want a "hot cam" or you'll loose low end torque.
Anthony Byars
1970 Ford F250 Crew Cab 390 C6
1955 Chevrolet 4 door sedan
2004 Ford Expedition
