FE Technical Forum
Mainbearing bore Dia.
Topic: Mainbearing bore Dia. (Read 3909 times)
February 10, 2016, 06:52:26 AM »
What is the mainbearing bore max and min Dia.?
In the block not inside the bearings
KMcCullah
Re: Mainbearing bore Dia.
Reply #1 on:
February 10, 2016, 08:04:35 AM »
I don't know what the actual FoMoCo tolerance was for the main bores (maybe Howie will take a look at one of his original block blueprints for us) but I've seen 2.941 which is on the tight side I think. 2.9415 seems like a more "happier" number.
Kevin McCullah
Howie
Reply #2 on:
February 10, 2016, 09:07:04 AM »
Main Bearing bore.
Drawing I have 2.9425" - 2.9417"
1967 Manual 2.9420" - 2.9412"
Reply #3 on:
February 10, 2016, 09:51:13 AM »
Thank you guys
FE Technical Forum
