Author Topic: How come most modern FE alum castings have the Extra Texture Finish?  (Read 10089 times)
Qikbbstang
   First Question: Got my Roush Timing Cover and it looks very impressive,  it has almost like very course sandblasted surfaces where it's not machined, both inside/oil wetted area and outside . There's a similar finish on modern Edelbrock heads and intakes. You compare these "new" parts to original FoMoCo intakes, timing covers, oil filter adaptors etc and they were cast very smooth not to mention they often sported typewriter sized print part numbers.. I don't know if FoMoCo used "finer" molds, different types of molding techniques for their castings, if it is from some form of agressively shot-peening the as cast surfaces?...............................
  Second Question: there is almost a rainbow color reflection from bright light on the machined sections - is this just from very fine machining of aluminum or some sort of clear coat/sealer applied to the entire part before/after machining?
 It all looks cool (modern but cool - it will stick out like a sore thumb if you used it on an all Ford FE motor). The modern castings textured finishes look to be road dust and grime magnets.  You can wipe grime off a FoMoCo timing cover with a Kleenex, you'd tear a Kleenex to shreds whipping it on a Roush cover.
Pardon my borrowing someone elses photobucket pic but his photo shows the surface perfectly and saved me the pic ordeal.
« Last Edit: February 04, 2016, 10:24:11 AM by Qikbbstang »
Lenz
Re: How come most modern FE alum castings have the Extra Texture Finish?
« Reply #1 on: February 04, 2016, 11:26:19 AM »
Can't speak to all of the issues, but I am in the metal finishing business.  Not only does the "rough" finish look decent (but hard to clean), it will and does hide a multitude of defects that might otherwise might cause extra finish work at the end of the line.  In more extreme cases otherwise perfectly serviceable parts could end up in the scrap bin.
I would think that other manufacturers like Edelbrock would also do this for the same reason to some degree, as little to no mechanical finishing work needed is needed on those surfaces.
Len Zielinski
'64 Galaxie 500 445 Toploader
'69 F100 300 stick
« Reply #2 on: February 04, 2016, 11:30:35 AM »
I think it depends on the foundry and the sand type that they use.  My first foundry for the intake adapters used a very fine sand, and the first 70 or so castings had a much smoother finish than the castings from my current foundry, that uses a coarser sand.  Probably back in the day Ford used a finer sand for the castings.  Everybody's got a process that they like to use, and the casting finish will depend on what sand is optimized for that particular foundry's process.
« Reply #3 on: February 04, 2016, 11:59:11 AM »
Look on the bright side BB, don't rough surfaces shed heater faster?
Qikbbstang
« Reply #4 on: February 04, 2016, 12:28:10 PM »
Drew I laughed so hard at your "bright side" I got tears in my eyes...Don't dimpled finishes also make the car go faster to because the course finish cuts through the air like a golf ball. (even under the hood).
 Wow I sure thought that was some crazy-ass top-secret type of shot-peening that couldn't be duplicated on all those new aluminum parts (you could make a fortune IF you could make old intakes look just like brand new intakes).
Qikbbstang
« Reply #5 on: February 04, 2016, 12:32:22 PM »
Hey you missed
« Reply #6 on: February 04, 2016, 12:45:12 PM »
The factory Ford timing covers are die castings - no sand involved
« Reply #7 on: February 04, 2016, 12:54:12 PM »
Hey you missed
That's just the machined surface.  A very finely machined surface will reflect colors like that.
« Reply #8 on: February 04, 2016, 01:46:15 PM »
What Barry said..
« Reply #9 on: February 04, 2016, 01:49:31 PM »
Now you are catching on..... that darn Roush fella is a genius.  Dang, now I have to send my whole car off to the powdercoaters.
« Reply #10 on: February 04, 2016, 02:16:45 PM »
On many of the castings you'll see the pebbled finish is the result of a post preparation media blast with stainless steel shot.  They will take the raw casting and hand deburr, remove all the foundry sprues and parting lines with a grinder, and then shot blast the part before finish machining.
« Reply #11 on: February 04, 2016, 03:15:07 PM »
My learning how to do it casting.
We used what is called green sand.
It was very fine almost like a powder.
bn69stang
« Reply #12 on: February 04, 2016, 07:57:49 PM »
You guys are killing me , lol - figure out how much hp they make and then get with Jay , he may have to re do all his dyno figures
« Reply #13 on: February 04, 2016, 09:13:41 PM »
Nice Howie im impressed 8)
« Reply #14 on: February 04, 2016, 09:47:57 PM »
Howie was that off Dave Gingery's plans?
