Author Topic: New FE Timing Cover From Roush  (Read 28520 times)
GJCAT427
Re: New FE Timing Cover From Roush
« Reply #30 on: February 02, 2016, 06:44:06 AM »
That little piece of tin for the pointer will let you mockup your motor. Degree the cam for TDC and make a mark on it for 0 degrees and mark off the fore and aft degrees for timing. Or use timing tape on it.  Bet it fits larger aftermarket balancers too.
ChiefDanGeorge
« Reply #31 on: February 02, 2016, 07:48:21 AM »
I ordered one since I needed one. Figure for $70 I'll try it, and Rock Auto didn't seem to show a supplier for an OEM one(or I'm not looking in the right spot).
Dumpling
« Reply #32 on: February 02, 2016, 08:20:45 AM »
I see Roush put up another (final) batch of their covers on ebay.  FYI
Qikbbstang
« Reply #33 on: February 02, 2016, 12:29:21 PM »
I thought it over for a while and got off my wallet for that $3.00 extra to have "The Cat In The Hat - Jack Roush" sign mine  --pretty darn good deal?....
 LOL in your dreams guys!    ............... I don't have a clue about Jack's signing anything
http://www.roushfenway.com/faq/how-can-i-obtain-autographs-from-roush-fenway-racing-team-drivers/
« Last Edit: February 02, 2016, 01:19:45 PM by Qikbbstang »
Qikbbstang
Just received my Roush Timing Cover
« Reply #34 on: February 03, 2016, 02:40:21 PM »
Just received my Roush Timing Cover --- 100% optical illusion on the fuel-pump thread location - looks great and I stuck a FE mechanical fuel pump in it just to see all is well.
   BTW: What makes the rainbow glare off the machined sections?
« Last Edit: February 03, 2016, 07:31:10 PM by Qikbbstang »
« Reply #35 on: February 03, 2016, 02:55:32 PM »
How's the thickness around the gasket area?
Tboggus
Re: Just received my Roush Timing Cover
« Reply #36 on: February 03, 2016, 03:30:40 PM »
Just received my Roush Timing Cover --- 100% optical illusion on the fuel-pump thread location - looks great.
Good news! Thanks for letting us know.
bn69stang
« Reply #37 on: February 03, 2016, 05:23:28 PM »
Still waiting for mine to show up , but thanks for the feedback ..
« Reply #38 on: February 03, 2016, 08:24:06 PM »
Here are some pics!  :D
So, maybe I bought two. ::)
Room to spare.
« Reply #39 on: February 03, 2016, 08:48:30 PM »
Pan rail area is 5/16" and block mating surface is 3/8" thick. Very robust looking. I like it. :)
« Reply #40 on: February 03, 2016, 09:37:37 PM »
Thanks for the gasket rail measure Jared.
Hey one more thing. Are the front pan bolt holes there?
Haven't seen that view in any pics. I see the corner front bolt holes but don't see the front.
They're prolly there, just no bumps or anything to know. Which suggests the casting is pretty thick.
Unlike the Shelby deal.
« Last Edit: February 03, 2016, 09:54:29 PM by turbohunter »
« Reply #41 on: February 03, 2016, 09:57:48 PM »
« Reply #42 on: February 03, 2016, 11:31:33 PM »
Marc, if you look above, you can see the bumps on the inside. It must be pretty thick towards the outer side.
And that was an optical illusion. That machining mark makes it look like that pump bolt hole is on the edge. Well played, Jack. Well played :P
« Reply #43 on: February 03, 2016, 11:51:39 PM »
I thought that was the Shelby part that had the inside bumps. ???
« Reply #44 on: February 04, 2016, 12:34:14 AM »
Shelby:
Roush:
