FE Technical Forum
Crank trigger
Topic: Crank trigger (Read 4699 times)
Crank trigger
January 26, 2016, 08:10:55 PM »
I was totally surprised to find out MSD does not make the FE crank trigger any longer. I was looking for one for a friends engine. I'll be using the innovators west setup on mine and could sell him my old MSD setup but I had planned to hold on to it. What are you guys using for a crank trigger now ? Just any 7" wheel ? BB ford or cbevy coughcough uggh.. The pickup mount is no issue cause its easy enough to fab something up.
Wtf would MSD discontinue the FE setup, ?
Keith. KB MAX Racing.
Administrator
Re: Crank trigger
Reply #1 on:
January 26, 2016, 10:14:36 PM »
Actually, I didn't even know they ever made an FE crank trigger. I've used the 429-460 setup with success, but as you mentioned you have to fab up a sensor mount. I think I just had to oblong the hole in the trigger wheel...
Re: Crank trigger
Reply #2 on:
January 26, 2016, 10:36:50 PM »
I have had mine for about 15 years lol. Not sure when they discontinued it. I did just see on MSD sight that they offer a universal 7" wheel kit that should work fine.
677litre
Jr. Member
Re: Crank trigger
Reply #3 on:
February 23, 2016, 06:41:51 PM »
I just went with an all-in-one distributor.
http://www.fuelairspark.com/fas/ford-fe-big-block-dual-sync-billet-distributorhtml/
Re: Crank trigger
Reply #4 on:
February 24, 2016, 01:45:37 AM »
It isn't hard to adapt one, i'm using a smallblock Orange engine one, just made a bracket off the two lower right timing cover bolts.
FE Technical Forum
Crank trigger
