Author Topic: power rack @ pinion steering conversion  (Read 5935 times)
bn69stang
« on: January 10, 2016, 06:14:13 PM »
Anyone do a power rack conversion , on 67-70 stang or cougar and use the canton rear sump pan , if so any fitment issues ? .. Bud
Autoholic
Re: power rack @ pinion steering conversion
« Reply #1 on: January 11, 2016, 01:34:30 AM »
Before you go this route, I'd suggest looking at this option...
http://www.fastfreddiesfabrications.com/shop/product.php?id_product=4
It's designed for use on Cobra replicas but it could be made to work on another application. Allows you to keep the factory look while still having power steering. And it won't be dependent upon engine speed. You supply your own rack.
~Joe
57 lima bean
« Reply #2 on: January 11, 2016, 08:54:10 AM »
Some modifications may be needed......   :)
bn69stang
« Reply #3 on: January 11, 2016, 05:26:12 PM »
Thanks for the feedback Joe , i will look at it and all options as i am try ng to figure out what suspension , and or what changes im going to make . I am looking at the colt 65 kit , i like the shock tower trimming for room and the bigger brake ..Bud
bn69stang
« Reply #5 on: January 12, 2016, 08:20:02 PM »
Thanks Jared , will check it out , looking at ride tech coil over setup right now as we speak ..Bud
bn69stang
« Reply #6 on: January 25, 2016, 04:28:55 PM »
Well guys i decided on the ride tech coil over level 2 front , upper and lower control arms and the H Q  coil over s , and the unisteer power rack kit . . Bud
