Author Topic: Aerospace components vacuum pump kit.  (Read 6157 times)
« on: December 30, 2015, 09:06:10 PM »
I bought my self a Christmas present, its. Remanufactured pump with all the other components being new.I stumbled into it on e bay and it comes straight from aerospace . They list the remanufactured kits for $599.00 on e bay which is a good $300+ cheaper than with the new pump kit from jegs or summit ($941.00).
They accept offers and I made one and ended up paying a tad less than $500. It showed up Christmas Eve and I'm eased with at least how it looks. I know its early on in my build and its not needed quite yet but at the time I felt sure I had that deal on the used DannyBee so I bit the bullet and got the vacuum pump system as well.
Russ67Scode
Re: Aerospace components vacuum pump kit.
« Reply #1 on: September 01, 2018, 10:20:16 AM »
I know this is a very old post  But wanted to know what drive did you use on the crank ?
Thanks Russ
« Reply #2 on: September 01, 2018, 12:26:31 PM »
i re drilled the large pulley to fit my innovators west harmonic balancer and used the drive that came with the set up. the spacer can easy be cut to the length you need.
« Last Edit: September 01, 2018, 12:30:42 PM by fekbmax »
Russ67Scode
« Reply #3 on: September 02, 2018, 10:46:48 PM »
Thanks
