FE Power Forums > Drag Week 2015
2016 Drag Week tracks announced!
AlanCasida:
Hot Rod got on the ball this time around and Yup, if I can get in I'm going. 8)
http://www.hotrod.com/events/drag-week-2016-track-locations-and-dates-announced/
jayb:
Sure hope you make it in, Alan. Especially if your FE Mustang is ready...
AlanCasida:
I am just about ready to squirt some primer on the 'Stang so yes, that is my plan. I just need to decide if I will keep the MII front end or go Gasser style with a dropped straight axle. :) Since I replaced the rear frame rails with 2x3 tubing(although still in stock location) I am not sure what class that would put me in. Plus a straight axle would be cool. If I go that route I plan to use a 4-link bar set up with coil-overs(ala Two Lane Blacktop '55 Chebbie) rather leaf springs. I think that setup looks cleaner.
jayb:
Unfortunately, you need the stock front frame rails to run in Street Race, Super Street, or Modified. Maybe the Gasser or Hot Rod classes? I'm not sure about the rules in those classes. And of course you can always run in Street Eliminator; pretty sure there's no rules there except 10.0 for the minimum ET.
AlanCasida:
I still have the stock front frame rails, it's only the rear I replaced. I might be able to get in Super Street, depending on how you interpret the rules or Modified if I install a ladder bar/4 link in the rear. At any rate I need to get the car painted and go from there.
Navigation
[0] Message Index
[#] Next page
Go to full version
