Author Topic: Axle and spline count recommendation for a drag car?  (Read 26021 times)
Re: Axle and spline count recommendation for a drag car?
« Reply #45 on: December 09, 2015, 09:46:07 AM »
Sounds right Nightmist66.  Depending on the track composition (ours is concrete) 50F can be borderline for any hook.  VHT stops working around those temps.  The way I set pressure is to pick a setting, make a run, then put my face right on the tire with a flashlight and look at the pattern.  I shoot for a fairly even wave pattern across the tire face.  Adjust pressure as needed to get that.
