Author Topic: Stuck Carbs  (Read 10132 times)
chris401
Stuck Carbs
« on: November 08, 2015, 11:04:43 PM »
 I have an Autolite 4100 and a Holley spread bore that have frozen shafts. Anything out there that will breakup the rust without scoring or dissolving the aluminium?
Thanks
fastback 427
Re: Stuck Carbs
« Reply #1 on: November 09, 2015, 09:21:45 AM »
You can try an ultrasonic cleaner. They will take off the dichromate finish but won't harm the aluminum.  Most machine shops have them.
Jaime
top end toploader
67 mustang coupe project
74 f100 xlt 390 c6 factory ac
Re: Stuck Carbs
« Reply #2 on: November 09, 2015, 11:26:32 AM »
I've used CLR the household cleaner but don't remember doing so with aluminum.
chris401
Re: Stuck Carbs
« Reply #3 on: November 09, 2015, 11:40:09 AM »
I have some clr on hand. I'll soak a broken base plate first to see what happens. Is ultra sonic cleaner used to clean off Zyglow or is it the vat solution?
fastback 427
Re: Stuck Carbs
« Reply #4 on: November 09, 2015, 12:31:09 PM »
An ultrasonic cleaner is a machine that uses ultrasound, with water or a cleaning solution. Used in jewelry shops, and hospitals, etc. A buddy bought one big enough for carbs and it works great.
Jaime
top end toploader
TorinoBP88
Re: Stuck Carbs
« Reply #5 on: November 09, 2015, 12:44:39 PM »
Not sure if its the best way, but onetime i saved an autolite by soaking it in diesel.
Re: Stuck Carbs
« Reply #6 on: November 09, 2015, 01:30:28 PM »
Try Evapo Rust or Metal Rescue rust soak. I have used Evapo Rust several times and worked great. Very easy on parts. I usually put the parts in a jar or bucket depending on the size and let soak overnight. You should be able to find it at a local auto parts store or similar. I found it at a local OReilly, but I think my local Farm and Fleet sells it too. I believe it was around $20-$25 for a gallon.
Re: Stuck Carbs
« Reply #7 on: November 09, 2015, 01:31:13 PM »
I had luck soaking Them in
WD 40
57 lima bean
Re: Stuck Carbs
« Reply #8 on: November 09, 2015, 01:33:43 PM »
SeaFoam may be your friend :)
chris401
Re: Stuck Carbs
« Reply #9 on: November 09, 2015, 03:48:32 PM »
I used that once in the accessory shop.
I'll post the results.
Thanks
Re: Stuck Carbs
« Reply #10 on: November 09, 2015, 04:54:20 PM »
Recently read about soaking carbs in Pine Sol.  Not sure how that works with rust.
Re: Stuck Carbs
« Reply #11 on: November 10, 2015, 07:24:24 AM »
For those of you that have never tried this stuff, it is magic.  I am not sure how it works, but I bet it would do great.  Its water based, leave it in there for 24-48 hours, then blow it out and shoot it with penetrating oil as a lube, I bet it would loosen up just fine.
Also, don't throw it out, it can be diluted a little and used over and over again until it's too filthy to put parts in
shady
Re: Stuck Carbs
« Reply #12 on: November 10, 2015, 08:50:52 AM »
my local walmart has it, & yes it is magic.
2021 FERR cool FE Winner
2022 FERR cool FE Winner
2023 FERR cool FE Winner
chris401
Re: Stuck Carbs
« Reply #13 on: November 21, 2015, 11:30:19 PM »
WD-40 nor CLR did the trick. CLR directs not to use on aluminium, but at this point there was nothing to loose. I'll keep working on the Autolite with Simple Green as recommended by Daytona Carbs. I can replace the spread bore base plate with a new piece for $150 through Holley, may go that route.
Re: Stuck Carbs
« Reply #14 on: November 22, 2015, 11:02:09 AM »
Buy some of that stuff we mentioned above.  It's cheap enough that it's worth a shot.  Evaporust for 24 hours, then a shot of some sort of penetrating lube could do it
