Author Topic: 1st FE build, looking for 1hp per cube with alot of low end torque  (Read 10818 times)
Re: 1st FE build, looking for 1hp per cube with alot of low end torque
« Reply #15 on: October 04, 2015, 04:05:53 PM »
Here's a link to my budget 390 stroker buildup in Car Craft.  $6K, 500 HP, 500 ft-lbs:
http://www.hotrod.com/how-to/engine/ccrp-0808-ford-390-fe/
Sounds like you have access to the machine work at no charge (unless I misunderstood), so that would knock about $700 off the cost of the build.  Replace the solid cam with the hydraulic, and lower the compression a little, and you've got an easy 440 HP and 480 foot pounds for well under $6K.
« Last Edit: October 04, 2015, 04:08:50 PM by jayb »
67Rancher0
« Reply #16 on: October 05, 2015, 10:21:14 PM »
OK, so after reading some more ( jays link ) and talking it over with a few people, I guess it makes as much sense to refresh the 390 as it would a worn out 302. It's less machine work to do 445 than  even a sbf. So the math is closer than I thought, so I just gotta decide if I want to go mild or closer to 500 if cost is relative
