Author Topic: Pond 510 Running Rich  (Read 21381 times)
BigBlueOvalFan
Re: Pond 510 Running Rich
« Reply #30 on: October 03, 2015, 07:26:14 PM »
Thanks for all the comments guys,  I truly appreciate the help.
Finally figured out how to reduce the size of the pictures from my digital camera.  Here is a pic of the #4 plug.  The #1 plug looked the same.
Let me know what you guys think.
« Reply #31 on: October 03, 2015, 08:53:17 PM »
I am sure you have done this, but ignition timing must be set before any tweaking on the carburetor. Just trying to cover the basics first.
« Reply #32 on: October 03, 2015, 09:24:47 PM »
What are you running for an ignition?  Doesn't even look like its trying to burn that plug clean
BigBlueOvalFan
« Reply #33 on: October 04, 2015, 11:52:38 AM »
Yep, set at 40 degrees at 3-3.5k rpm.  I may back it down to 38 as it's straining the starter a bit.
BigBlueOvalFan
« Reply #34 on: October 04, 2015, 12:00:21 PM »
MSD 6AL with MSD distributor.  The vacuum advance is plugged.  Everything is new.  It might be a faction of total run time as it's spent more time idling that any thing else.
« Reply #35 on: October 04, 2015, 12:09:49 PM »
I realized we are talking about mixture here but I went back and tried to see what plug you're running. I didn't find if you said.
My 441 has to do lots of idling in traffic so I use a hotter plug (45s) and they stay very clean.
BigBlueOvalFan
« Reply #36 on: October 04, 2015, 04:27:41 PM »
I'm running NGK R BKR6E plugs.  The car is a weekend warrior and rarely gets driven but if it does, it's on the street only, not in traffic. Looks to be in the middle of the heat range, nothing special.
« Last Edit: October 04, 2015, 09:03:27 PM by BigBlueOvalFan »
