Author Topic: Warped Holley carburetor body repair and carb rebuild questions  (Read 25790 times)
Re: Warped Holley carburetor body repair and carb rebuild questions
« Reply #15 on: October 04, 2015, 11:12:45 AM »
Sounds good Clark, I am home now, we have an engagement at 3 that requires a shower first, wife would kill me in my sleep if I miss either the party or the shower. (That sounds way more fun than what I meant LOL)
Should be around next weekend too if today doesn't work.
I will offer a couple observations if you decide to go at it this afternoon.
1 -  Point gap and coil check - Make sure your point gap is dead on.  Loosen the distributor to get it perfectly on the point cam, then adjust and make sure the points are clean.  Also, make sure your coil is wired up the right way.  "Dist" or "-" goes to point side.  I have seen a couple over the years that guys get them backwards by accident.
2 -  Set initial timing higher - 10 degrees at 1300-1400 is likely not enough timing especially at that RPM.  Get it at 12-14 at a 750 or so idle, vacuum disconnected and plugged to distributor and make sure ported vacuum is dead.  I have a hunch you have the primaries open too much, see below.
3 - If ported vacuum is not dead at whatever idle you are at, pull the carb and close the primaries and open the secondaries an equal amount.  Then reinstall and readjust. It might take a few times, you are looking for about .020 of transition slot up front and a nice 750-ish idle.  Once you get close and it idles, set timing, resent a/f mixture to highest idle then lower to 750 again.
Beyond that it'll take some thinking and listening.
runthatjunk
« Reply #16 on: October 04, 2015, 09:42:13 PM »
Has this happened since manifold install? Wondering about possible vacuum leak?
1965 390 Galaxie 4 Speed
1966 428 Thunderbird
Clark Coe
« Reply #17 on: October 05, 2015, 11:27:21 AM »
This is Engine Tuning 101 and I am failing. More notes and observations.
Today, with the coil removed from car, checked Primary/Secondary resistance with calibrated Fluke meter, Primary = 1.5 Ohms. Secondary = 7800 Ohms. This is correct with Ford spec's.
Sunday, opening and closing points to fire coil, generated blue/orange arc that will jump .25" gap to ground.
Coil wiring has always been wired correctly. Seen that done wrong in the past and wouldn't forget that sick yellow spark.
Saturday, I measured point dwell = 28 degrees. That seems about right to me.
These are very old points and condenser. To get the engine to fire, had to clean points with a dollar bill to remove fine corrosion film to make contact. Have heard that most new points/condensers are foreign made and of very low quality and not reliable. So that is my excuse for keeping the old points.
I have a new Pertronix II and Blaster coil that I intended to install after the initial start-up and tune, but did not wish to introduce any changes until I had a stable patient.
Can anyone recommend a quality brand of points/condenser?
Removed carb last night to inspect intake/carb gaskets......all looked OK. Checked carb base to carb body screws.....all tight (snug?). Bowl screws are snug.
Both Primary butterfly plates have a small hole (drilled) in them. How much trouble will this cause?
Checked tightness of intake bolts....all tight.
I have never ran this Streetmaster intake before. Craigslist purchase. Seller said it did not deliver good driveability on his dad's pickup and they changed to a Performer and liked that better. Never thought too much about that statement. I guess there could be some porosity issues with this intake. before installing, I blasted it and worked with it a considerable amount and did not see anything suspicious. I did grind some required clearance between the 3/8" push rods and the intake, but not much material was removed and never thought I was close to the intake ports.
I still believe the poor ( none existent ) idle is a vacuum leak. but, I do not want to remove the intake manifold just yet.
Clark Coe
« Reply #18 on: August 08, 2017, 03:15:30 PM »
This is a two year old thread and I am resurrecting it because I am again working to find and correct the problem(s) to establish drivability to my ‘68 Mustang after letting it set for two more years….life has been keeping me busy.
After working on the Mustang last weekend, it now has a smelly 750 rpm idle that roams up and down 25 rpm. Vacuum at idle is 14” and it also fluctuates slightly. Initial timing is very high, not sure how high (18-20?). Engine still starts with the engine warm. Timing is difficult to read, but the distributor is rotated clockwise almost to thermostat housing. Gasoline is fresh and fuel system is clean.
The carburetor is a Ford C8OF-D 4150 style that I purchased at a swap meet 30 years ago. The primary throttle plates had small 1/16" holes that appeared to be factory, very neat clean holes, positioned very precisely. Last weekend, I replaced the primary throttle plates with plates without holes. Also opened up the position of the secondary plates to expose the secondary transitions slot a small amount.
Here is my problem/question:    My carburetor has threaded adjustment screws that are horizontally positioned in deep threaded wells in the carburetor base throttle body. These needles protrude and partially block the openings of the Primary Idle Discharge Holes. One needle is threaded so deep as to be sticking through into the air path of the throttle bores. Light weight penetrating oil will wick past the screw points, so I guess some gasoline is getting through. However these screws must effect the idle quality.
I have several 4150 and 4160 series junk carburetors and none of them have adjustment needles in the Idle Discharge Holes. PLUS, these slot head adjustment screws are very stuck, I cannot back them out. What is the purpose of these needles and how to get them unstuck? Anyone familiar with these adjustment screws? I could try to get some pictures if that would help.
« Last Edit: August 22, 2017, 03:23:21 PM by Clark Coe »
« Reply #19 on: August 08, 2017, 06:01:38 PM »
The screws in the baseplate you are describing don't sound right for a C8OF-D Holley. There should only be the idle screws on each side of the primary metering block. There is of course the curb idle screw, and the tiny screw underneath that controls the secondary plate adjustment. I just looked at a C8OF-C Holley I have and it has the tiny holes in the primary throttle blades, so that is probably correct. What throttle arm does your carb have? Is it the usual Ford style used on the 390 GT carbs? Can you post a picture?
Clark Coe
« Reply #20 on: August 09, 2017, 10:40:24 AM »
Kevin, here is a picture of the throttle linkage. Looks to be standard Ford issue.
The small holes in the two primary butterflies is very neatly done, it has to be a Holley factory feature.
Yesterday, a friend loaned me the Ford Holley carb from his restored '67 GT FB. This carb was recolored and restored by Holley and is a known performer. I am curious to try this different carburetor.
After I remove my carb, I will post pictures of my hidden, adjustment screws that are embedded in my carb's throttle plate.
« Last Edit: August 09, 2017, 10:44:47 AM by Clark Coe »
« Reply #21 on: August 09, 2017, 12:15:01 PM »
Clark, I cannot see the pictures at work, but any a/f adjustment other than the metering block is either something custom or baseplate off of some other carburetor.
Some comments though
1 - Points have to be replaced at some point, get a decent set of Accel or NAPA and associated condenser.  Set the gap and set timing and press on with the carb
2 - If those screws block the idle discharge holes and are stuck, then you have no ability to adjust the a/f, as the functional effect of that is the same as the ones in the metering block.
3 - If you have both the baseplate screws and the metering block screws, assuming the idle passage lines up to the throttle body, I would remove and plug those screws and use the ones on the metering block.
4 - Conversely, if you cannot remove the bottom ones, and the metering block ones are present, back them way out, then use the baseplate ones to limit/adjust
RJP
« Reply #22 on: August 09, 2017, 12:17:48 PM »
To the best of my knowledge Holley has never used drilled primary throttle plates as shown in your picture. In fact, earlier Holley publications have in so many words condemn the practice. It is usually done to crutch an idle problem on an engine that has a huge cam that won't allow it to idle without opening the throttle blades beyond the idle transfer slot.  To add: If you have idle mixture screws in the base plate you have the wrong base plate. Only 4180 Holleys had idle adjustment screws in the base plate and usually had "limiters" on them to prevent them from being turned beyond a very small amount, it was an emission thing.
« Last Edit: August 09, 2017, 12:22:20 PM by RJP »
« Reply #23 on: August 09, 2017, 12:21:34 PM »
Actually Holley did use both drilled Primary and drilled Primary & Secondary plates in many carbs, both factory applications and aftermarket ones, including the HP carbs. I've just looked at a few more C8OF-C & C8OF-D carbs I have and they all have the drilled primary throttle plates ( with "211" marking ).
Edit to add - Holley even sells replacement throttle blades with various sized holes already in them.
« Last Edit: August 09, 2017, 12:40:39 PM by thatdarncat »
« Reply #24 on: August 09, 2017, 12:33:28 PM »
So I did a little closer looking, it's been quite a while since I've rebuilt one of these C8OF carbs. All the C8OF-C and C8OF-D carbs I have on hand DO have something resembling a needle tip in that hole, but NONE of them have any kind of external adjustment screw head. If they are adjustable it would have to be down inside this hole. This is a feature that must have been new for the 1968 model year, because none of my C6OF and C7OF 390 GT Holleys have that feature. Right now I can't see down into this tiny hole well enough to see what's in there, I will try to clean it up some and see if that helps. I'll be interested to see a picture of the baseplate of your carb, so far other than the screws you describe all seems normal. Sorry for not looking closer on my previous answer, but I didn't see any screws and didn't look close enough underneath.
« Last Edit: August 09, 2017, 12:38:01 PM by thatdarncat »
Clark Coe
« Reply #25 on: August 09, 2017, 01:03:15 PM »
Yes Kevin, that is the same adjustment hole configuration as my '68 GT carburetor....thanks for the pictures and research. Looking inside there is a slot head screw. One of the screws on my carb is screwed in so tight as to almost block off the Idle Discharge Hole. I could dribble penetrating oil through it. I never made this adjustment, this carb came that way from the swap meet 25 years ago.  I sold my original 390 GT carburetor 40 years ago when it was attached to a '69 Mach 1.
How to get these screws loosen up?  Heat?  I have already buggered the edges of the slots a little when attempting to disassemble the carb in the past.
What is the correct needle position to have a clean idle?
This web site states that the C8OF-D carb was used on IMCO pollution systems.  C8OF-C carburetors were for Thermactor systems.
http://www.mustang-s.com/years/1968/1968_carburetors.htm
« Last Edit: August 09, 2017, 01:09:26 PM by Clark Coe »
« Reply #26 on: August 09, 2017, 01:20:53 PM »
I just looked in the Ford Parts book and it lists the C8OF-C Holley as 390 GT with manual transmission and Thermactor emissions, and the C8OF-D Holley as 390 GT with C6 automatic transmission with Thermactor emissions also. I'm not an expert on the two emission systems, so I'd have to do a little more research to see if that is correct. Maybe someone here knows more.
Clark Coe
« Reply #27 on: August 18, 2017, 01:13:57 PM »
Here is an update on tuning my C80F-D Ford-Holley 4150 carburetor. I have finally fixed the nonexistent idle condition by removing the outer portion of the obstructive adjustment needles that plugged up the IDLE DISCHARGE HOLES in the throttle body base. I purchased this carb at a swap meet and it was like this from the beginning. The left idle discharge hole is partial blocked as well. This adjustment option must have been a Ford/Holley attempt to fine tune emissions in 1968 only.
Working vertically down into the well behind the Idle Discharge Holes, I centered punched the visible portion of the needle with a start divot with a sharpened 1/8” roll pin punch. Purchased a new, sharp 1/8” diameter drill bit with a flatter 135 degree tip to prevent wander. Drilled vertically down into the idle well and drilled the needle in half. Using dental picks, I fished the remains of the needle out of the idle well. Cleaned with carb cleaner aerosol and compressed air.
The outer half of the adjustment needles with the adjustment slot remains corroded and stuck in the throttle body, is super stuck and keeps gas from running out.
Idles at 700 rpm with 18.5” vacuum. Idle adjustment screws in the jet block are one turn out. Looking back, this problem should have been obvious. I am a little embarrassed that I could not have been quicker at resolving this, but am satisfied that my car starts, idles and motors down the road. Thank you for everyone's support and input.
« Last Edit: August 18, 2017, 01:41:39 PM by Clark Coe »
« Reply #28 on: August 21, 2017, 05:57:05 AM »
Well done Clark, and thanks for the research and lesson on the early carbs.  I have never seen that idle a/f adjuster before.  I am sure you are correct that it was a sealed limit for emissions so you couldn't back out the top adjusters and go any richer than the bottom will allow.
So are we going to see the car at Cars and coffee  this year?  The season is dwindling away quickly!  I likely will not be there this weekend, either working on a Pontiac, or going to Speedway Motors in Lincoln for their version of Cars and Coffee and museum, or if I can pull it off, both LOL
Clark Coe
« Reply #29 on: August 22, 2017, 04:18:10 PM »
Thanks for the help and encouragement Ross. Yes, I will need to show up for the Omaha Cars & Coffee before September goes away. Summer is always busy for me, got a three quarter acre lot that requires mowing every fourth day, in addition to my wife’s flowers.
The Speedway Motors, Museum of American Speed in Lincoln is one of my most favorite places on the planet. I have visited the museum three times so far and will go again. Love the vintage dirt cars and the flathead ford speed equipment and the Indy Cars and the Miller/Offenhauser exhibit and the tin lunch box collection and the peddle car collection. Any car person traveling through Nebraska on Interstate 80 should make time to visit this world class automobile museum.
Also Ross, I wish to congratulate you on your promotion to a “Full Bird Colonel” as my late AF NCO Uncle Merlin used to call them. That is a hard earned title to be sure…..Clark Coe
